tonyweiss11
I've been reading around on many of these great forums on how to increase MPG, when to shift, RPM, driving style etc. to try and get the most out of my TDI in lifespan and in MPG. After reading a lot of different threads there seems to be a fair amount of contradiction on increased MPG vs the life of the engine and turbo. So I've got a few question I want to throw out there and see what is best because I'm still a little unclear.
Current Status:
2001 Jetta TDI, ALH engine code, 5 speed. 228K miles, put 50K on since owning it and averaged 46.7 with a roof rack and bike holders for last 25K or so.
What I know:
Don't lug the the engine. Use 5th gear as much as possible. Once a week or so run through the roof on the rpms pedal to the medal in 2nd, 3rd, 4th to blow the crud and soot out. Don't waste time on cold starts, start driving immediately. Anticipating driving for light, stops, hills and downhills. Coast in gear as much as possible when <50 mph. Coast in neutral when >50. Depends on situation of course but as a rule of thumb. Don't rev engine to high when cold. Try to shift above 3K rmp most the time. Peak torque is 1900 rpm. Try and stay in range of 1900-2500rpm. Increase speed increases wind resistance by the sq. so the faster you drive the more air resistance = less MPG. Ideal speed is 55-60mph. Try to avoid using breaks as it is lost KE. Observe the 120 rule for estimated mpg vs. speed. Filters replaced at specified intervals, oil changed with T6 every 10K miles, tires at or near max psi, and other regular maintenance, timing belt. Coasting in gear uses no fuel while coasting in gear uses 0.5 Liter per 1 hour. Pulse and glide method for hypermiling. Shut engine off if you think it will be running longer than 10' as it takes roughly 10' worth of fuel to start up if warm.
What I don't know or am unclear on:
1. How to use the Right foot? Does actually using a heavy right foot help mpg vs a light one? I have read it does and doesn't. Specifically getting up to speed for hwy or cruising speed should I have a heavy foot in short accelerations up to or above 3000rpm or a lighter foot with longer accelerations?
2. When accelerating up to speed, especially in city driving where terrain is relatively flat and speed limit is +/-45mph. Should I punch through gears by accelerating fast and getting up to speed and cruise in 4th? or take a slower acceleration up to speed and flip flop between 4th and 5th when needed?
3. Does using a heavy right foot in 5th gear keeping rpm at 2000 or above have better mpg than using a lighter right foot in 4th? Example going up a hill, I can keep it in 5th by going heavy right foot and keep rpm above 2000 but I feel this may use more fuel than dropping speed a little and shifting to 4th with a lighter right foot. I'm not sure though.
4. When shifting up, does every shift need to be up to or above 3000 rpm, going from 1-5th? I feel like when I do this in the city I end up wasting energy by having to break for the next light or car in front.
5. I know I should use 5th as much as possible, but in driving small hwy or city how does this effect mpg if you use 4th at around 40-45mph to keep from lugging engine vs 5th?
6. When coasting in 5th on a flat, downhill or up to a stop is it okay to leave it in gear at 1100-1200 rpm if no lugging appears to be going on and no right foot is applied, strictly just coasting in gear at a low rpm in 5th. Is this the same for other gears as well?
7. Is it okay to accelerate from low rpms (1300) in 5th on flats or downhills if it is gradual and light right foot? I know trying to punch it from low rpms is bad on the turbo.
8. When accelerating, what rpm should be a rough target to start? Example, say you roll up to a light in 3rd and right as your getting there it turns green, rpms are 1200, should I gradually accelerate in 3rd, downshift to second, or heavily accelerate in 3rd?
I know these are semi specific scenarios but I think they are very relevant and the concept is what I am wanting to understand so I can apply them to my driving style to increase MPG but still take care of the engine/turbo so my TDI will live a long life! Many more miles to come.
Feel free to add or change or correct me on anything
-Tony
Current Status:
What I know:
-Tony
