Stock are eh... even after changing the lens covers to glass..
I have see LOTS of aftermarket ones... HID ones, dual beams E-Code replica's and even some actual e-codes...
Still not clear as to what is actually regarded as an excellent headlight for a 2003 MKIV Jetta
What do you say?
I have an 03' Jetta, GLS, and have had it for about 5 years. In that time I have gone through about every variation, suggestion and opinions from other forum members and outsiders, to improve my lights, and I wound up with a couple of shelves full of useless lights. In also have two MK 4 Golfs, and those lights are Hella e/codes from Germany, with +bulbs from Candlepower in Rockville Md. Those lights border on 'awesome'. So, I decided to just stop messing around and replaced the front clip on the Jetta, with one from a MK4 Golf, and installed a set of Hella MK5 E-code lights (in a MK4 configuration), along with the aforementioned bulbs, and a custom light bar, using Hella 550 driving lights and Cibie' 175 fog lights, all with 100 Watt bulbs. The result is that I basically "replace the sun after dark". Driving 72 miles at night through 'deer country' to get to work, they have pretty much taken away the 'white knuckle' driving, that I was doing before the change.
