BigTurboAlh
Whats the stock alh pistons and china beams good for?
24/25 psi boost before you replace the head gasket and used stronger head bolts.Whats the stock alh pistons and china beams good for?
Ok, Buy the CRAP. Get the big and little ends fixed before you put them in. But will you get rods balanced at both ends? Not in your life.Maxspeeding rods off ebay. Even comes with arp bolts for $275 http://www.ebay.com/itm/Connecting-...ash=item33b08dcdc1:g:ykwAAOSwL7VWpdHG&vxp=mtr
Nural pistons from rockauto
yup, my china rods needed to be honed and very well may not be balanced, but I'm buddy-buddy with my machine shop guy, he did them for $40.Ok, Buy the CRAP. Get the big and little ends fixed before you put them in. But will you get rods balanced at both ends? Not in your life.
Next thing is the pistons are not as good a deal when you buy one set imported from UK. We buy multiple sets to reduce cost per item imported, then we match piston weights that are close to each other for reciprocating sets. Finally we balance the pistons to the rods. It's no more expensive the way we do it and you get better results.
Same car... 1Z engine with stock internals. Third year starting now with same setup, just bigger nozzles changed month ago. Dynoed 377HP/600+Nm last autumn with small ( 0.341mm ) nozzles. New ones are with bit less than half mm holes, hope to have 400hp without NOS.
I´ve never seen bushless TDI pistons, all 1Z´s has also been with exactly same pistons than AHU´s and AGR´s. I think there haven´t been bushless pistons on euro markets and it´s only a problem of some older engines on US markets. I have ´94 engine on Golf, and propably it would be already failed with bushless pistons.I don't know how anybody would think a 1Z piston would push 400hp...
First, the older pistons have no wrist pin bushings. The ASV and ALH engines all have bushings, but only the ASV has an oil galley. That is a big cooling improvement.
Yea may be, still few horses below. Won´t still replace them before fail.running 400 on stock rods wont last
heh, I think that most ITT are well beyond such meaningless consumer-grade terminologyWhat i want to say guys. Leave all of those "stage1, stage2, stage3" softwares, they are CRAP. Make proper custom tune, and you will have better durability and power.
I know this is an old post,Maxspeeding rods off ebay. Even comes with arp bolts for $275 http://www.ebay.com/itm/Connecting-...ash=item33b08dcdc1:g:ykwAAOSwL7VWpdHG&vxp=mtr
My brother has this combo of piston/rods in his Golf along with the same mods in my sig. 200+ hp with over 13k miles so far so good. The whole rotating assembly was balanced.I know this is an old post,
But did anyone go the maxspeeding+nural route?
Are these rods what they claim too be?
