Outlaw534
I’ve read lots of opinions. I’m wanting to role some coal in higher revs but maybe not all the time. Or maybe all the time as long as it doesn’t hurt my MPG. Would love to hear what y’all have to say.
If you dont mond smoke and you want that look. Go to facebook group ( tdi scumbags) yes that's what they are called and so will you be.okay, thanks guys. im more interested in injectors that improve power and performance. I did see somewhere somebody was complaining about injectors causing smoke and I was just saying I wouldn't mind smoke I think its kind of cool. but im far more interested in seeing an improve in performance.
I never said to get rid of it. Bro I ran 13 second 1/4 mile runs on a decked out 98 jetta ahu with about 5 grand under the hood.Lol, your telling me to get rid of my jetta if I want it to go fast? nah im good thanks for the advice I guess. but these cars can go fast lol there's no way you don't know that. so im not sure what your agenda is. Please explain why im the problem my car needs a little bit more power?
As a helpful hint for you, you may want to remove the "cold air intake" especially on the mk4, it causes a lot of problems with the maf sensor, due to the oil in the filter and the dust it allows in. Look in the TDI power enhancements section for the thread on the cold air intakes.I have coilovers and I’m about to install ceramic brake pads with a vented disk. I don’t mind a little hate for the rolling coal part. I get that. I’m just wanting a little puff to show it’s diesel lol. I was hoping to get a few cheap mods while saving for a stage 2 tune from kerma. And a set of 200 dollar injectors. And eventually a bigger turbo. I just got my TDI so only thing done to it is a cold air intake.
I've got a stock air box you can have for the shipping. If you want power, you'll need that. A new maf will just be ruined by the cold air intake and you'll be at square one again. The air box I have has a maf with it, which I believe is good. Came from a parts car I had.Okay guys, thanks for all the input. I’m excited to start this build thanks for all the advice. I do not have a stock intake to put on it. If I buy a new Maf sensor with the cold air intake would that work? And would it be ok to put injectors on before a tune? Last question lol I know I’m a noob but When I’m looking for a turbo I want something that will spool up at a reasonable rate. How would I know what turbo would spool up early in the revs but stay spoiled up to higher revs?
That's a hacked knockoff. They are often filled with viruses and don't work well. Go to ross-tech.com they're $199 and work way betterLike this? https://www.ebay.com/itm/VCDS-VAG-C...2349624.m46890.l49286&mkrid=711-127632-2357-0 and as soon as you guys said I needed oem intake I texted a friend of mine who need my oem intake. And he said he isn’t using it and would give it back. Now, as experts would you recommend a turbo or injectors first?
if i were you id go injectors first because you can run them without getting a tune, although i dont believe you would get the absolute most out of them without one. but still a lot more punch over stock injectors. make sure your injectors are good to pair with an upgraded turbo so you can save yourself the pain of having to install different ones, a turbo upgrade could require more fuel than a modest injector upgrade.Like this? https://www.ebay.com/itm/VCDS-VAG-C...2349624.m46890.l49286&mkrid=711-127632-2357-0 and as soon as you guys said I needed oem intake I texted a friend of mine who need my oem intake. And he said he isn’t using it and would give it back. Now, as experts would you recommend a turbo or injectors first?
