thechoochlyman
I have an Ultragauge, but it doesn't work right. Is there anything out there that doesn't need calibration?
That's weird. Coasting in gear should be 999 or 999,999 or infinity, since zero fuel is being consumed. Maybe the Ultragauge reads things differently.About 60~ish, IIRC. Coasting downhill in neutral is like 150, though.
Closed 'throttle' when coasting in gear shows what instantaneous MPG?
I suspected not, and that's why I asked.Glad to see this thread updated and the Ultragauge working properly.
Lug_Nut:I suspected not, and that's why I asked.
Now I have no doubt that it's not working correctly.
The Ultragauge is using the MAF and air flow to guestimate the fuel use. Perfect for a throttle plate equipped engine and a regulated air and fuel ratio, but useless in a diesel with unregulated air flow.
You won't get accurate fuel use when measuring unrelated air use.
From what I have read and seen the Scanguage is alone in correctly interpreting fuel use by measuring fuel use. All the other plug-in monitors I have investigated use air flow.Does the Scangauge also use the MAF and air flow to guestimate fuel use? Or does it use the Injection Quantity to guestimate fuel consumption?
Ummm, yes and no. There is still fuel being moved to and from the tank and recirculated within the pump, but none is injected for combustion. As RPM drops closer to idle the injection quantity gradually increases, starting at about 1100 and under full ECU control by the 900 rpm idle.So our fuel pump cuts fuel completely upon deceleration?
That's what I needed to know....but none is injected for combustion.
What you do is set the nozzle on low and after it shuts off, you slowly keep adding fuel. It will foam some so what you do is let the bubbles dissipate and slowly fuel some more.One more thing. Because diesel is such a foamy fuel, it is difficult to refill the fuel tank to exactly the same level every time, even with a vented tank.
The air flow is somewhat independent of the fuel use. The engine load / power production is not related to the air flow.Even still, measuring air intake instead of IQ, would this not still be a good meter to find best MPG at specific RPMs...
I have used this method to top off the tank ever since I vented the tank. But with the wagon, I have to add around 8 gallons of D2 at very low fill rates. Usually takes between 5 and 10 minutes to get the last 8 gallons in the tank. Then pen and paper to calculate MPG.What you do is set the nozzle on low and after it shuts off, you slowly keep adding fuel. It will foam some so what you do is let the bubbles dissipate and slowly fuel some more.
After a few times of doing this, you will end up with clear fuel just shy of spilling over the filler neck. Extremely accurate, and only takes a couple of more minutes to do.
Pen and paper calculations are the only accurate way to calibrate what ScanGage is telling you.
I think the method for calculating MPG described in post #6 would be accurate, as well, but still pen and paper.
So just out of curiosity, how does the engine displacement and tank size affect the MPG reading apart from filling up the tank and telling it how many gallons it took, according to the manual?2. Once you're sure of your mileage, calibrate said Scangauge. You calibrate it by changing the gas tank size, and the liter engine size. I haven't messed with diesel a, and diesel b, but you might monkey with those too. Between the first two presets though, I've been able to dial my scangauge in pretty well.
For instance: on my old b4v I set my fuel tank size at 27 gallons, and had the engine size at 2.0 liters (it was tuned/injectors/etc). This got me to within 5 miles over a 10 gallon tank. Not too shabby.
My new b4v is set at 25 gallons for the tank and the 1.9 liters, and so far it pencils out to within 10 miles per 10 gallons. Again, pretty good.
I too would like to know how the thing works. I have followed what the manual says about filling / pricing but the mpg function doesn't report properly. First it was way over what it should be then I reset everything and now it sticks around 1.4 all the time. I just ignore it now really.Finally managed to score a scangauge on eBay for relatively cheap, so we'll see what kinda MPG improvements I can get.
It probably defaulted to settings for a gas car whenever you reset it. And no telling what engine size it thinks it has.I too would like to know how the thing works. I have followed what the manual says about filling / pricing but the mpg function doesn't report properly. First it was way over what it should be then I reset everything and now it sticks around 1.4 all the time. I just ignore it now really.
I did figure out how to adjust the speed so it reports accurately and consistently with GPS.
Steve
Here's what the scangauge told me this morning:I've never quite wrapped my head around this part. Is the engine actually running, or is it off and rotating (while all sensors are live) since it's connected to the driveline?
-Todd
