shoebear
- Joined
- Aug 1, 2002
- Location
- Colorado Springs, CO
- TDI
- 1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
I will be building new axles for my 2003 Jetta in the next couple of weeks with GKN inner joints and Metelli (boxed as Meyle) outer joints. I'd like these axles to last as long as possible, so I'm wondering if I can do better than the grease, boots, and clamps provided with the bearing kits.
GREASE
I'm thinking of using Redline CV-2 grease instead of the black molybdenum disulfide grease that comes with the joints.
According to Redline marketing info, "Red Line CV-2 Grease is designed to withstand the extreme temperatures and pressures which occur in high-performance wheel bearings and CV-joints." and "The exceptional extreme-pressure performance and the fluidity of the synthetic oil allows increases in bearing life of 200% to 800%. Red Line CV-2 Grease contains a red moly compound which is a superior lubricant to black moly disulfide lubricants."
Here's a video showing testing of synthetic greases -- CV-2 against Royal Purple. RP is not a moly grease, so I wouldn't consider that, but the test results for CV-2 are interesting. Bottom line: CV-2 beat RP as long as water was not involved.
BOOTS & CLAMPS
The best joint and grease will fail quickly if the boot fails. I have seen several boot failures where a crack developed at the inner edge of the small clamp, and others that develop in the folds of the boot. So maybe there's a better boot material that resists these problems, and maybe there's a better small clamp that's easier on the boot. Or maybe I should just go easy when I crimp the small clamp.
In addition to rubber boots, there are plastic, silicone, and even Kevlar ones. There are boots which can be stretched over the entire CV joint so the boot can be replaced without removing the joint. I did that with a Flexx-Boot FB3001 on my right outer joint about a year ago. Today the joint is bad, but the boot looks like new -- so the joint was probably already bad when I installed the boot.
At this point, I'm inclined to use CV-2 grease with stretch-type boots and just go easy when I crimp on the small clamp. But I'd like to hear what has worked for others.
GREASE
BOOTS & CLAMPS
