Best Battery For My Tdi And Why?
Does your TDI have a VW Battery or not?
  • Total voters
    423
mrrhtuner
London Ont Canada
2003 Jetta Wagon TDI, 2015 Passat TDI, 2015 Touareg TDI
I'd say you got your money's worth out of that possibly 12 year old battery. Hope I can get close to that from mine. I've had good luck with the everstart maxx batteries in other vehicles. I've got two in my truck right now.
I agree.
Initially I was thinking of trying to save a few bucks and open the old battery (Varta IIRC) and add some distilled water if needed. I will try to keep it still but for the convenience, we will replace it.
The EverStart battery cost me $137.xx + tax in Canada. The local VW dealer wanted $159.00 for the Enertec battery.
Reading the opinions of many regarding Enertec, I would rather give EverSmart a shot again.
  • Like
Reactions: Ton
tikal
Southeast Texas
2004 Passat Wagon (chainless + 5 MT + GDE tune)
So what is the going rate of the EverStart MAXX-H7/R94? Something around $150?
This is the one I go recently for my Passat:
http://shop.advanceautoparts.com/p/...ttery-group-size-h7-850-cca-h7-agm/10210826-P
Important specs for our TDIs for this battery:
* Reserve Charge = 140 min or 80 Ah
* CCA = 850
Online I got them to match the price of the Walmart EverStart Maxx battery for $150 with better overall specs so I think it was a good deal.
mrrhtuner
London Ont Canada
Tikal, the EverStart Maxx-R94/H7 is $137.xx Canadian.
I did find something interesting.
The one I purchased had a circular sticker of 3/15. It had the main sticker that identified the following:
-9 year limited warranty
-Part #: MAXX-94R
-Cranking Amps - 985
-Cold Cranking Amps - 790
There was another battery the same as mine with the circular sticker identying 6/14.
Now to make things interesting, there was a 3rd Everstart R97 battery.
-The sticker on the top of the battery identified a 5 year limited warranty
-I think the cold amps were slightly different and the cold cranking amps were the same as the other two.
-It had a circular sticker of L5 on it.
I do know that Wal-mart no longer has the 9 year warranty, they got rid of that and it's 5 years now.
L5 from what I understand is December 2005.
http://www.firestonecompleteautocare.com/repair/reading_date_codes.pdf
So this 3rd battery was manufactured in december 2005?
tikal
Southeast Texas
Wow talk about not-fresh battery!
I just checked and the cost of the Walmart EverStart MAXX-H7/R94; it is $150 plus tax in the Houston, TX area so that's a good price in Canada. Is its reserve charge also 140 min?
  • Like
Reactions: Ton
GWbiker
Arizona
2015 Golf S TDI 4dr.
How many of us remember the good old days, when a battery for an early '70's Mercedes Benz Diesel weighted 60 lbs and the starter weighted close to 80lbs and had to be rebuilt after several years.
Slow heating glow plugs, too. Took forever for the glow indicator to go out....:D
Today's TDI technology is going to spoil us.
  • Like
Reactions: Ton
tikal
Southeast Texas
The one I got (size 94R/H7) wighted around 52 lbs so not that much lighter.
  • Like
Reactions: Ton
Mark SF
SF Bay Area
2013 Passat TDi
I agree.
You can open the old battery and pour distilled water in if it makes you feel good, but it won't make the slightest bit of difference to the performance.
Any lead acid battery over 5 years old will be extensively sulphated, which has the effect of making it lose the majority of its Ah capacity.
If you're lucky, you might get a 5 Ah, 50 CCA battery out of the exercise which will then die anyway when it loses the last of its capacity in 6 months time.
  • Like
Reactions: Ton
mrrhtuner
London Ont Canada
What I find odd is that if the L5 sticker is correct and corresponds to December 2005, then why does it have a sticker towards the top identifying the 5 year warranty?
I've read that EverStart now has the 5 years as opposed to 9 years previously. Somebody at the factory must have put on the wrong date sticker I'd think?
Here is the main sticker.
  • Like
Reactions: Ton
mrrhtuner
London Ont Canada
Thanks so much Mark :)
I was thinking that maybe I should try to re-condition the battery but I didn't know what kind of a bandaid that would be.
I will dispose of the battery at wal-mart to get my core charge back and not worry about keeping clutter in my garage.
  • Like
Reactions: Ton
Stringer
Mount Pearl, NL
1999.5 Golf TDI
Deka Junk ???
Deka's are junk. They won't even last on year in my Kubota diesel zd28 and they leak alot to.:mad:
If you are going to get a non OEM battery I only recommend Exide batteries.;)
I guess there are opinions one way or another. I've had a Deka for years with no problems starting winter after winter in Newfoundland.
Google Deka and there are hundreds of positive recollections by people regarding Deka ... recreation, marine, truck, farm equipment etc.
Here is just one example:
I have an interesting story on Deka batteries! We run them in all our farm equip. and have had great luck. Our 100H.P. turbo diesel 200 Allis Chalmers loader/mowing tractor had 2 of them in it. I went out to blade some snow a couple of winters ago and the tractor would not start, it was only 30 degrees. I don't have electricity in the shed where the tractor was, so I started to take the batteries out to bring them in for a charge. I took the first battery out and reached in to get the 2nd battery out, i did'nt weigh as much as the first one. When I got it out I noticed the positive cable was broke and the entire back of the battery had frozen and busted out!! The surprising thing was the battery had a bunch of shredded grass and crap inside the broken case!! I guess the battery had frozen and busted the winter before cause it was not charging due to the bad cable. The tractor had started weekly for around a year on only 1 battery!!! Oh yeah, the batteries I took out were 11 YEARS OLD, NO JOKE!!! I just threw them both in the truck and went to town and bought 2 new Dekas' Anyway, that is my story. Catch ya later, Brian
So take everything with a huge grain of salt.
  • Like
Reactions: Ton
993er
Canada
None
Same here and at least they manufacture their own batteries unlike others that are relabeled.
Plus East Penn has some excellent technical manuals available for download. People just need to read them.
Any battery is junk if the charging system is junk. My charging systems are spot on which is why I get 15-plus years out of my standard car batteries.
  • Like
Reactions: Ton
Diesel Larry
Sarasota, FL
'09 Jetta
So... Now that several years have gone by, I am wondering how those that bought AGM batteries are holding up?
Did the AGM battery last? Did it die before the warranty? Is it still working?
What were the symptoms when it started to die?
Did you try another AGM, and how long did it last?
Thanks!
  • Like
Reactions: Ton
vincej
Calgary
2014 Golf Wagon
I needed a battery for my 64 Rambler. The Motorcraft battery in my mfd 11/97 ford was too big so I put in a piece of 1/2" plywood so it could overhang the box. It is still in the car and working fine. Beat that, 20 1/2 years. No battery blanket and sitting in the car still connected in an unheated garage it has started every spring for years.
For my other cars I find Costco batteries the best bang for the buck.
The original 2013 VW battery lasted only about 6 months but since I bought the car in January suspect it had been sitting in the lot with it dead and frozen.
  • Like
Reactions: Ton
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Batteries will last a long time if they are taken care of. Kept fully charged at all times and filled if needed/required. Not ever run flat. I have one in my 1935 Ford that is 12 years old and doing fine so far. It is 6 Volt. Starts 2 or 3 times a week too.
  • Like
Reactions: Ton
~TDIguy~
Romulus Ny
2005 Jetta Sedan
We have a small engine repair shop and Everstart (Neverstart) batteries are scoffed at here. Weve seen brand new batteries that aren't worth a thing
  • Like
Reactions: Ton
hymato
NorthEast PA
2010 jetta TDI(buyback) Now 2005.5 Jetta tdi
So what’s the best battery for a BRM MKV at this day and age? Is AGM no good? I’m looking for the best battery before winter.
  • Like
Reactions: Ton
cheezy
Madison
99 NB, 96 B4V
Just look it up on Costco's website, AGM is fine.
You can handpick the newest one off the shelf at China-Mart.
My Everstarts have been fine.
  • Like
Reactions: Ton
Hyde7278
Central Mich
2001 Golf GL
I know that I'll get flamed for this but I bought one from Walmart w/a 5yr warranty. Car sat for about a year and when I charged the battery from being compleatly dead it would not take a full charge. So I brought it back with out a receipt and was given a new battery and new 5 yr warranty.
I would buy one again just because of th warranty and the ease of replacement.
  • Like
Reactions: Ton
Mongler98
COLORADO (SE of Denver)
YEP, a quality battery tender would revive that battery though.
  • Like
Reactions: Ton
belome
Mid MI
2002 Jetta GLS TDI 5-speed
Well, if you did in fact get that then Kudos to you. However, that isn't how it is supposed to work. The warranty shouldn't restart again for 5 more years.
Which is why normally if you have a prorated warranty and you are in say year 5 of a 6 year warranty and they charge you 20 or 30 bucks less than what a new one would cost you may as well just buy a new one and get a new 5 year warranty.
That is how they sucker you in!
  • Like
Reactions: Ton
tikal
Southeast Texas
For what is worth, my personnel experience putting an AGM battery in my 2004 Passat did not pay out the extra cost. It barely lasted three years (Advanced Auto Parts did honor the warranty even though it was past two weeks or so). Most likely because AGM batteries do, on the average, worst in heat than regular 12 volt automotive batteries.
Probably AGM batteries will be ok for mild to cold climates.
Another factor for AGM batteries is the voltage coming out our older TDI alternators not being 100% compatible. Do some searching on this also before going the AGM route.
  • Like
Reactions: Ton
Andyinchville1
Virginia
2003 Jetta TDI wagon, 5 sp, 226K miles
Hi, ,
Anybody here running a good light weight lithium battery ?
I know they are some $$ but lightening things up helps performance / economy.
Andrew
PS - For now I am running a factory stock battery bough through the VW dealer.
  • Like
Reactions: Ton
reince
GA
2006 Beetle
My buddy also had bad experience with AGM batteries. He replaced it just after 2 years due to inconsistent voltage.
  • Like
Reactions: Ton
werdna
An obscure corner of northeastern Massachusetts
2003 Jetta Wagon, 2013 Touareg Sport, 2015 GSW
The good news: that was six years ago and it's still about $150.
What's probably bad news: at least around here (New Hampshire) all the stock is no longer made by Johnson Controls, it's now unbranded "Made in Turkey".
I bought one anyway (with more time and cope I'd have gone to Interstate instead), as my eight-year-old JCI battery was getting marginal on starting. Will see how it goes.
  • Like
Reactions: Ton
Ton
Free Union,VA
early 2001 jetta
The local auto parts store wants $145 for my tdi battery. I will see how long it lasts.
JB05
Il.USA
Golf,2005,anthracite blue
I recently found an Interstate H7/94R for my Golf at a local Midus shop.
  • Like
Reactions: Ton
StrayCat
Chisago City, Minnesota
2001 Audi allroad tdi project, 2003 Jetta TDI 5spd 117k, 2003 Jetta Tdi 5spd 410k and counting, Sold. 99,5 Jetta Tdi 5spd 270k went to a new home.
A group 49 battery fits perfectly in the tray with the plastic sides removed; Mine from Napa is 900cca and 1080 ca.
  • Like
Reactions: Ton
