GoFaster
Moderator at Large
The inherent disadvantage of a transmission that has lots of ratio choices so that it can have the most efficient gear at any given time ... is that it's going to change gears a lot if the programming is optimized to make use of it. If you program it so that it immediately picks the proper gear, a twitch of your foot will make it downshift and upshift. If you program in a delay ("are you sure?" - most production examples are like this) then you get that hesitation and bog before it makes up its mind. If you say the heck with it and go CVT then it feels like a rubber band.
The old 3 speed autoboxes only downshifted if you mashed the accelerator all the way to the floor, or when you came to a stop. You pay the price at the pump and in acceleration. The torque converter slippage covered up what would otherwise be lugging. IIRC the 6 cyl AMC Hornet that our family had (a LONG time ago) took 17 seconds to get to 60 mph and got about 17 mpg ...
