Limitedblack
Has anyone managed to code new keys with just a cluster & ECU on a bench setup?
I have VCDS working fine in the car, but on the bench it throws up an error when running “test” in key programming.
car is 2001 golf V5 AGZ engine with Bosch 3.8.3 motronics ECU. On the bench I have a setup with original key reader, and can run a cluster so immobiliser is not activated (runs with a correct key).
so far I have powered up the same model ECU on the bench, and it is readable through the k line. I have also added the canbus lines that also look to run (passes the VCDS coms test, and fails if I swap the high/low lines). Engine light also operates on cluster when canbus connected. So pretty sure all that works.
ECU connections are
power pins 1&3
Ground pin 2
K line pin 19
Canbus pin 41/29. Connects to cluster pins 19/20 green T.
have tried w-line on various pins of ECU (comes from cluster pin 5 (green). Pin 18 & 43 on ECU both have the same effect of killing the communications in VCDS (controller not found).
running out of ideas.
ECU connections are
power pins 1&3
Ground pin 2
K line pin 19
