Hatchet Ratchet
i've just replaced the head gasket, tandem pump gasket, intake and exahust manifold gaskets, cleaned out intake and intake ports, replaced turbo oil feed line with braided, replaced camshaft, lifters, cam oil seal, and take out for the 20 min / 2k rpm break in drive for the new camshaft and drained the oil just after filming this video.
i reused the belts and water pump as they only had 26k on them. i did not mark the direction of the belts. i do not want to do anything with the timing belt if possible.
does this sound like a belt noise, turbo noise, or boost leak noise?
there was only a boost leak hiss from the pancake pipe to intercooler joint prior to taking everything apart. i replaced the o-ring seal, inspected the tabs on the pipe and put in a new clip at that joint.
any suggestions on what to look for or trouble shooting steps or perhaps someone who had the exact same thing.... and your solution would be wonderful?
thanks
https://youtu.be/G2-LxwUo7KE
thanks
