NWMO Tercel 4WD
Hello vw folks. I am interested in trying to find a suitable diesel swap for the AL25 Toyota Tercel wagons. Below is a pic of the odd bell housing and the very limited clearance on the bottom as the engine sits on top of the front differential. Here is a link that shows the 3a oil pan or one very similar.
oil pan
The flywheels are quite similar in dimension (the Toyota is slightly smaller), this pic is of a 4age flywheel for a gas engine swap that has been modified and the stock starter ring added. You can see the very tight clearance needed on the bottom. Any help with real numbers (dimensions) for the 1.6 tdi or any other suggestions would be appreciated. Thank you for your help.
Chris
oil pan
Chris
