VelvetFoot
Mine are pretty well adjusted, just having to move the vertical adjustment. Not getting flashed so that's a good sign.
Hmmm...let me know if you do start stocking; I'm lookingdanix said:Perhaps, but I also now own a 98 Beetle.
The ability to change the cutoff of the beam pattern is found on all the recent VWs with projector headlights in Europe. The completely straight cutoff isn't what is found in the US. It's that way so if the vehicle travels to England (or any other country that drives on the wrong side of the road ) you're not blinding every oncoming driver. The US lights have a modified version of the "kinked" cutoff found on the European cars.madelgado said:This is the headlight:
The back of the headlight:
Now it is set with the Euro pattern... I will zoom inside:
You probably guess on the left of the image the small handle and also the moving parts that define the pattern... a bit on the left you can see:
yes, that piece is the handle that moves the pattern. Clearer pictures for both patterns:
US PATTERN:
... and EURO PATTERN:
That's all. Hope this helps!
Time for me to set up a email notification for that search... thanks for sharing that you found a pair - that they're still out there for sale.JetPuf said:well, good news. did some searching, and found some! YAY! didnt post it here though till I won the auction. hahaha...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180074955639
I searched for "Scheinwerferumrüstung" which translates using google to "Headlight re-equipment" on ebay.de and found a seller.
the euro assembilies take an H1. the seller in the link i provided mis posted the bulb info. he actually contacted me saying i could get outa the auction if i wanted, but it really makes no difference to me, i just wanted the NB ecode insert.BudsBug said:Do the Euro assembilies take a H7 and not H1 bulbs???
Thanks for the explanation... I had no idea about that... just saw the pictures of the New Beetle and thought that it was for what I explained. I will delete the post so that noone gets messed. Thanks!Pelican18TQA4 said:The ability to change the cutoff of the beam pattern is found on all the recent VWs with projector headlights in Europe. The completely straight cutoff isn't what is found in the US. It's that way so if the vehicle travels to England (or any other country that drives on the wrong side of the road ) you're not blinding every oncoming driver. The US lights have a modified version of the "kinked" cutoff found on the European cars.
