Mike,
Yes, the very first mod I put on the Wagon when I bought it in '06 was a Panzer Plate. It paid for itself in the first week when I ran over some debris on the freeway, in traffic, at 70MPH. WHAM! That would've torn the oil pan clean off, but the Plate was only scratched. The Panzer Plate is aluminum, so it probably weighs less than a steel plate, but still...
I also run tires one size taller than stock: 205/65R15, on the stock alloy wheels. After the suspension refresh, my next step is to get a set of 16" steel wheels and find some Mud & Snow tires for my off-pavement adventures.
You've never scraped? That's what I am trying to achieve. I often carry a canoe on the roof and a week's worth of camping gear in back. Last summer I ended up on a 2-track in the woods and scraped the Plate for a quarter mile before the road leveled out.
Since I need to replace the springs, I wanted to get all my lift from the springs, not spacers or lift kits. Theoretically I get more suspension travel that way.
1/2" rise from the front MOOGs is minimal, but a firmer ride would be good and you can't beat the price! I wonder if there is a taller choice?
My concern with the rear MOOGs you installed is that you're in a Sedan and I'm in a Wagon. According to idParts and other sources, the 5 green dot springs are European market rear springs for the Jetta Wagon with the towing package, not the same springs as sold in the wagon in the US, and they'll cause the car to sit about 1" higher in the rear and are noticeably stiffer. So I'm looking for an equivalent for the 5-green-dot springs. As best I can tell, the Monroe SP2070s will do it, but I'm hoping someone here in the Forum can confirm.
Thanks for the reminder on the bushing bolts. I'm going to take a close look at the bushings when I have things disassembled, and might take the opportunity to replace/upgrade. You're right, it's no picnic but I've got experience with a NB and an Audi A4.
Narf:
I don't tow with the Wagon, but I do load it down. For example, the family is planning another Spring Break in Big Pine Key, Florida. That's over 1,500 mi (24 hours straight through) each way - and the Wagon will be loaded with 2 adults, 2 teenagers, a week's worth of gear, and kayaks on the roof.
