Rickstah
Good information, thanks. I have been running some replacement Wagner struts with a 1.5" pipe spacer above them for a few years on my 2002 ALH NB and the lift was good although the ride was bad, lol. If you hit a very sharp bump it sounds like a hammer hit but slow speed action is acceptable. I would like to just get some replacement struts with an extra 1.5" or 2" lift so I can replace the pipe and possibly get a more compliant shock. I have some taller coils on back that do a good job, I think they were mentioned when the gent who first started the pipe spacer thread mentioned them as replacements.To get a longer front spring so that I only need one 10mm spacer per side or none at all, I dug up these from the 2019 Lesjöfors catalog:
40 950 31:
13.00mm wire
137mm o.d.
367mm free length
style: C I
40 950 33:
13.00mm wire
141mm o.d.
340mm free length
style: C I
Since stock is 12.5 mm wire diameter, I searched only 12.75mm and 13.0mm diameter in order to get stiffer spring rates. 13.0mm is the same wire diameter as the VR6 front springs that they sell with the towing springs from ID Parts.
The 340mm version there shows up in the Rock Auto catalog for $35/each! That's 15mm longer than the 325mm VR6 front springs that ID Parts pairs with the European rear wagon towing springs.
LESJÖFORS 4095033 Coil Spring | Shop Now at RockAuto
LESJÖFORS Suspension Parts and More for Your Vehicle at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.www.rockauto.com
*for anyone looking for a little bit of lift in their sedan, I will have a set of the standard wagon springs available for next to nothing here in a few weeks... Those plus the $150 Evolution lift kit spacers would you fairly decent for a sedan.
I need to look again to see if taller springs require a longer shock.
