• Server migration complete
    In the early morning of September 26, 2020, our migration to new servers was completed.
    Things seem to be working as expected, but if you notice any issues including not receiving email notifications,
    please vistit this thread for more details
Battery relocation.
TwistedSmoke
Milford ,Pa
03 Jetta tdi
Ok i relocated my battery the trunk. I ran 0 gauge positive wire to the front, and 0 gauge to the ground. But now i was thinking about adding a fuse next to the battery as a just in case. what amp fuse would i add in? I was think 250 or 300 amp but i am not sure any ideas would be great.
KrashDH
Washington
2002 Golf
1/0 seems way overkill for these cars, but I guess that's not a bad thing.
I built cables for my 04 Cummins. All the main cables I made from 2/0.
The alternator cable I ran 1 AWG and protected it with a 250A slow blow fuse. I would think 250 would suit you just fine for that wire. Just remember the larger the fuse (especially on those big guys) the longer they take to fail. So you could have the wiring subjected to HIGH amperage for a period of time.
I'll usually analyze the load rating for the circuit, see what the wire can handle, choose basically a good middle ground where I don't have to worry about popping the fuse when the circuit is loaded, yet it's de-rated from the wire capabilities so you're not dancing on the hairy edge of melting any wiring. Remember too, adding length of wire increases resistance therefore lowers the current rating. There are tables out there that can give you a good idea of load capacity per foot length.
Interesting mod though, would definitely clear up some space under the hood!!
TwistedSmoke
Milford ,Pa
03 Jetta tdi
Well i used a 150 amp alternator fuse which is what the stock one ran on. I was just adding a fuse to in the trunk to protect the the main line that runs threw the car
KrashDH
Washington
2002 Golf
Fuses are made to protect wiring from melting. Nothing more, nothing less. I was giving my suggestion based on wiring size. My alternator wire in my truck was used as an example because it's close to the one you're running.
KrashDH
Washington
2002 Golf
The starter can draw 300-500 amps... might need to factor that in depending on how you've re-wired the car.
That seems really high to me... These starters, the specs are around 1800kw...so 1800/12-ish = 150 A.
If you're drawing in the range you've listed, something isn't right.
But it depends on the starter, connections, etc.
Nero Morg
OR
Realistically I'd set it at 150a just because that's the max I've ever seen any battery fuse on any car/truck. If your starter pulls more than that, you have other issues.
KrashDH
Washington
2002 Golf
If you use a 150A you're likely to pop it when you try to start the car... Based on the power rating of these starters you'd be on that "fine line". With things like starters and alternators, there can be amp spikes as well, which generally exceed the fuse rating, but they're quick and don't harm the fuse
You're likely going to want to use a "slow-blow" fuse like the Mega... They're used in GM applications (a quick spike won't take the fuse out like it could a "standard" fuse)
Remember, you're protecting the wiring from overloading, not designing one to be "just a bit higher" than the load.
Ok i will add a 200 amp one as a just in case
I'd look for a 250 Mega
TwistedSmoke
Milford ,Pa
03 Jetta tdi
Would you happen to know if these fit an ANL fuse holder. Cause i have a single large ANL fuse holder from an old project car.
KrashDH
Washington
2002 Golf
No, they have different hole/connection spacing. You'll need a holder specific for the mega.
That being said, I've bolted one of those mega fuses in-line in a prior application with no I'll effect, you just have to keep it from touching anything else.
I've also seen one side bolted to the battery post clamp and the other side bolted to he cable. There's a few ways to go about it.
Vince Waldon
Edmonton AB Canada
Yup, that's my point. The hp rating is a good start for figuring out typical current draw but on a cold winter morning the spikes will be higher and last multiple seconds... long enough to melt an inline fuse.
In this case the fuse the OP is proposing also has to supply 50A to the glow plugs, other electrical loads not on the X circuit, *and* the starter.
KrashDH
Washington
2002 Golf
100% agree, which is why I suggested the 250 for that setup, and it has to be a slow blow fuse which isn't effected by those amp spikes. If there are other things turned on as well, those count as load on the system. Another reason why when you're load testing a battery, it's good to turn on as many accessories as possible while turning the car over (ie headlights, fans, radio/sound system, etc).
TwistedSmoke
Milford ,Pa
03 Jetta tdi
well i found a shop near me that carries ANL fuses and i tried out the Fuse box i had here with a 250 amp fuse and it worked last night and turned on the car. But for some reason today went to start it today and after the 2nd time cranking the car over the fuse popped. So what do you guys think might have cause this is maybe 250 not enough for everything in the car?
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Well fuses also protect devices (like the ECU) from damage. Since all the devices in the car are protected and the battery is essentially always "on" I see no benefit of fusing it. A shut-off (disconnect) might be handy.
KrashDH
Washington
2002 Golf
I thought I mentioned this in my earlier post but maybe not...I may have just thought it.
You cannot use an ANL fuse in this application.
As Vince mentioned (as well as myself) even though the starter may have constant draw of 150A, there are/could be very high spikes in the current. ANL fuses are not meant to handle any spikes at all.
You need a Mega fuse like I suggested because they are a "slow blow" fuse that resist the high current spikes.
I'm pretty sure most parts stores should carry those mega fuses although I'm not sure if they will carry 250A ones.
This is a good point too. With 1/0 wire I wouldn't see the need to fuse it from the battery. In my situation I was protecting the alternator wire from overcurrent. Instead of putting a fuseable link on my alt wire (they don't make an appropriate fuseable link for 1AWG) I had to use a slow blow fuse. Instead of making my cable more complicated (something in-ine) since the alt cable connects to the battery directly, I just fused that wire alone. They make a battery terminal post mount slow blow fuse that worked perfect for my application.
OP, are you running the 1/0 to your starter too?
Vince Waldon
Edmonton AB Canada
There is no fuse to the starter on the factory wiring... of this or any other car I'm aware of... and I'm thinking you're finding out why. :) :)
FWIW, the cars that have the battery mounted far away from the engine (like the gasoline fuel Vanagons, for instance) have a MASSIVE wire (with the insulation and covering, it is near garden hose size) to the starter. Not sure why you relocated your battery in the first place, but you really cannot use "too big" of a wire in this instance (within reason, of course).
wonneber
Monroe, NY, USA
2014 Jetta Sportwagen, 2014 Tiguan,2003 Jetta 261K Sold but not forgotten
Has anyone thought about winter when the motor oil gets heavier and the starter needs more amps to crank it?
I was also wondering why relocating the battery other that maybe it seemed like good idea at the time.
I would want the extra weight in front for traction.
TwistedSmoke
Milford ,Pa
03 Jetta tdi
i am relocating the battery first to give me more space up front when i need to work on the car. Also i have some mods i plan on doing that might add weight up front so the battery not being there should be fine.
Andyinchville1
Virginia
HI,
By chance do you have pics of how / where you routed the wires and how you secured the battery to the floor.
I am looking to relocate my battery but since I have a wagon , my plan is to put it in the passenger side rear floorboard area.
Andrew
TwistedSmoke
Milford ,Pa
03 Jetta tdi
I ran the wire threw the grommet that is location to the right of the brake reservoir behind the wire tunnel. i then ran it down the driver side of the car near the other wires that go to the rear of the car under the plastic door sill. If you need pics i will try to get them when i get home
