Battery Question
peace_of_soul
Indianapolis, IN
2000 Jetta, 2012 Passat
Does anyone know if running a battery all the way down and having to jump start it (twice) will ruin an alternator?
Does anyone know how to test for this issue?
Thanks!
naturist
Bro Jerry's hometown, Virginia
2001 Jetta TDI, 2005 Jeep Libby CRD, 2012 BMW X5 35d
Shouldn't, provided it was properly jumped.
take the car to Autozone, Advance Auto, Pep Boys, or any dedicated battery place, and they should be able to test both the battery and the alternator.
But wait, if you ran the battery down twice, did have a dead alternator to start with?
JB05
Il.USA
Golf,2005,anthracite blue
A quick test would be to put a volt meter across the battery leads while the engine is running and see if you get at least 14 volts.
Some kind of load test would be the next step as stated above.
gforce1108
Newburgh, NY
It is very hard on an alternator. They are designed to maintain a charged battery, not charge one from dead.
rdkern
Humboldt Co CA
It seems to me to be likely the alternator was bad to allow the battery to drain twice.
Joe_Meehan
Ohio USA
NB TDI, 2002.5, Silver
They are connected. Usually a healthy alternator will survive a battery dying once or twice, but not always. Also a bad alternator can kill a battery. Have both checked before just replacing either.
MayorDJQ
Williamstown, Mass
'10 Golf 2dr 6m, sold.
And before replacing the alternator @ $300+ (assuming you don't plan to replace it yourself) replace the $50 voltage regulator.
