Mountaineer51
Its on and will not go off even with rpm change. What diagnostic steps should I do and in what order ?
Uhh no. I do have a volt meter . how do I do it.Have you measured the voltage with engine off and with engine running?
alternator
Now an explanation like that is what I like to see.As the name implies, the alternator produces alternating current, which is not compatible with the electrical system. It must be converted to direct current to be usable. The conversion is done by diodes(there are 6 of them) which allow current to flow in only one direction. If one fails, it can allow current to flow from the battery through the alternator when the engine is not running, and will reduce the alternator output when it is running. Hoping this helps clear up the mystery.
Paul
