AlexP
- Joined
- Mar 8, 2001
- Location
- Fairfield, IA, USA
2001 TDI Jetta. 130,000 in Iowa with salt on roads in winter. There are many threads about radiator fans and burned wiring and failure etc. But I cannot seem to find what is happening to me.
Last spring the fans would not go off and killed the batterie. I charged the batterie and things seemed to work OK. Then I noticed that the fans did not work. At all. ie no AC. So I was due for timing belt and asked dealer to look at. Dealer explained there was corrosion in the connector that connect to the radiator fan cables under the battery at the lower drivers side corner of the radiator.
A month later I had no fans again. So I got some electrical cleaner and did it again. Looking at the connector I see corrosion. This time the fix seemed to last longer. In fact up until now. However I have another problem. When left at airport parking lot for week or more. Batterie is dead on return. Car is fine when driven every day or two or three. Current drain at batterie is 200 mA. But if I disconnect these two connectors to the radiator fans current drain is 30 mA.
Anyone seen anything like this? Suggested solutions?
Many thanks
Many thanks
