eb2143
I am replacing my 2001 single din Monsoon receiver with a JVC unit from Crutchfield with the harness they supply. e
Following the Crutchfield instructions shouldn't be an issue as they are very straight forward.
Before I do, however, I wanted to double check that by following these instructions I will be getting the best install. The two primary areas that I've seen mentioned on other MKIV headunit installs are:
- Is the power in the factory harness key sensed/switched in the single din units? Some installs tell you to tap into the 75x terminal or a fuse to get switched power. I *think* if I use the Crutchfield harness I will end up with a radio that works with the key in the ignition but not without a key (slight downgrade from stock)
- I'm assuming the K-line is not an issue with the Crutchfield harness? http://www.ross-tech.com/vag-com/aftermarket-radio.html
