bmike
Thread Killer
On my otherwise clean and rust free 98 A3 Jetta, it is bubbling around the door check hole on the driver side rear door. I'd like to remove the door for easy application of POR 15, both on the inner and outer portion of the problem area. Do I remove the door from the hinge or the hinge from the body, or can the hinge pin be removed? It has crank windows so I'm guessing that the rubber flex conduit is for that tiny speaker next to the inner door handle, (I always thought that was a fake)? Is there any trick to removing that?
I've read the POR 15 web site, but am not completely clear on prep, do I scrape the rust away first? Any help is appreciated. Thanks.
