Some places use different types of machines, and some machines are in dire need of recalibration. And some wheels are bent, some tires are not round, so no amount of balancing can fix that.
One place Balanced my tires. But after driving and went back they rebalanced. To make a long story short, I went to another place because VW said my rim was bent. But this place said rimm good but the tire is off. Maybe radial belt too tight. Balanced the tire and it was off by .50
Well stand by the person spinning the wheel/tire on the machine and look for yourself. The wheel is bent or it isn't. Bent wheels, for whatever reason, are VERY common on these... and given your location I am sure the roads are not friendly to them.
You still have not answered my original question. Is there a reason you had them balanced? Did you get new tires? Has the car been sitting? Is there a vibration at a specific speed?
New wheels and tires there use to be a vibration at around starting at 45 mph. I felt it in the rear. I move the rear left to front left and rear subsided but felt the front had issues(Not as bad) around 65mph. That is when I went to VW who said wheel bent. then I went to a third place who said tire and also saw the front left tire off by .50. It is riding better now but I want to make sure its really good!!!
So I went to Mavis which uses a COATS Balancer. All four wheels were off. Total Static should be less than 25. All four tires were over 40. Two over 75.
Its all about how you mount the wheels for the Hunter Machine. Looks like with COATS machine you mount the wheel unles its on the correct size HUB.
