riofrio
A few weeks ago I started noticing what I thought was "shuddering": just some mild vibration at the gas pedal at certain rpms, barely noticeable otherwise.
Well, it's been getting progressively worse and just after 2 or 3 weeks it is getting to the point that it is very uncomfortable to be in the car (especially for passengers). I wouldn't call it "shuddering" anymore but rather "shaking". Here are some symptoms and pertaining info:
- It seems to happen only with light-to-medium throttle. It will go away if I either let go of the accelerator, or if I give it some boost.
- It does not seem to correlate to any specific wheel or engine speed. I'm fairly certain it is not drivetrain or wheel related, but rather engine or fuel delivery.
- It does not seem to be the "slow-down shudder" that people have mentioned in these forums: it simply goes away when I let go of the pedal.
- When I do give it boost, it pulls very nicely.... maybe not 100% but good enough.
- The IP is freshly rebuilt from DFIS, timing belt replaced less than 10K ago, and injection timing is slightly advanced (just under the top line).
- No smoke, even when I floor it. Car's got 320K miles on it and I believe the injectors and nozzles are still original stock.
- Oh yeah, my idle has been getting rougher in the exact same time frame.
- No CEL, no engine codes (well, other than the 01117).
I suspect (even though without fully understanding why) that this shaking might be related to badly toasted nozzles or worn injector(s). I'm getting a rebuilt set of injectors with Sprint 520 nozzles from Frank's VW TDI's, but he is on back order and it will be a couple of weeks.
But if it was related to nozzles or injectors, wouldn't I be seeing a lot of smoke? If anybody has seen something similar, or have some suggestions or questions, please chime in...
