turbonem
Hello to all
My 2002 wagon has symptoms of bad lifters.
When revved cold it will miss,
If its pushed beyond 2000 rpm cold it will stall and if its attemped to restart sounds like there is no compression.
After 10-15 seconds from what I am assuming is the lifter pump bleeding down restarts normally.
When cold, if the rpm reaches
1800-2000 rpm it begins to miss,
And surges until it gets past whatever is causing this.
If I short shift it and keep the rpms below 1800 after a few miles this symptom goes away.
Im in colorado so a cold start is usually 32 f or below this time of year.
If It is left to idle and warms up 10 minutes or so its past the third hash mark on the temp guage (160F) it can be driven without this symptom.
The data:
Mobil 0-40 euro oil.
The oil pressure:
45 psi on a cold start @ idle.
Max oil pressure at any temp is 65 psi.
Idle is 1100 rpm with dynamic idle from malone stage 4 tune.
I posted a question about this symptom a while back and a guru said bad oil pump relief,
So I replaced the oil pump with a factory vw oil pump with no change.
The oil pressure measured with a guage where the oil idiot light switch resides measures the max pressure when cold is 65 psi when revved cold,
You can see the relief open on the guage.
Idle pressure when warm or hot is 25 psi.
Once fully warmed up,
Temp guage reading 190 F and a few miles of hwy driving this symptom goes away at any rpm.
Once warmed up it can be driven across 5 states without a problem.
Iv read thousands of posts to tried to find someone with a similar problem and the only post with similar symptoms and a resolution was replacing the cam and lifters ( that was all that was replaced and the symptom disappeared and cured the problem.
So,
Does this sound reasonable?
The facts are oil pressure is in spec,
Cold starts are the only time it misses,
Once warm it runs normally.
Im getting ready to do the timing belt anyway and would also replace the cam and lifters if this would solve the cold miss.
Thanks for reading
Cheers!
The data:
The oil pressure:
So,
Thanks for reading
Cheers!
