burn_your_money
98 ahu. 1 size larger nozzles by Giles.
The car starts and drives fine under normal use. It seems low on power a bit but I’m not used to the AHU so it could be normal. It has a bit of a Smokey haze, not normally visible during the day but sometimes is. Definitely visible in headlights at night. It’s up to date on all maintenance. Power comes in around 2200 but is gone by 3000. It won’t rev past 4000 in 3rd and the engine starts running noticeably rough above 3000. Cam is a Colt Stage 1 less than 20,000 miles ago.
What’s the best way to test lifters? Try and push them down and see if they are squishy? Anything else to check?
