diesel_smoke
I like to know what symptoms will show with my 01' tdi when an injector is bad or going bad? I'd rather not get into my cars issues but again list symptoms of a faulty injector.
It really depends on the quality of fuel. Theoretically, if one uses a good fuel additive that has lubricating, cleaning and water-dispersing properties, the injectors can last indefinitely.SharanTDI said:How often is it normal to replace injectors?
Bad injectors will also increase emissions and engine wear.oilhammer said:More times than not on a TDI bad injectors just means underfueling, which means low power.
My local guru, Jon Hamlton up in Marysville (Rally TDI?) says 80k.How often is it normal to replace injectors?
That's what we're looking for, thanks Steve.Well I went to 350k on stock nozzles.
Started to get some smoke on start up and poor fuel economy.
Switched them out to sprint 520's.
Happier now.
I am unaware of this electrical component in this age of tdi. Tell me more.The injector have a mechanical and Electrical component. The electronic side controls to the solenoid and may be OK, thus no code is given until it fails. The mechanical may fail to work well. In this manner, there are no engine codes, but the car is hard to start after sitting overnight and may require 3-4 tries to start until pressure builds up.
Could be a weak lift pump or tandem pump.From my understanding, the electronic part controls the solenoid. One of my injectors leaked pressure over a long period time of sitting, there were no codes but the mechanical aspect was failing to maintain pressure when starting. After a three tries, it would start and run fine all day. Even parking it for hours, it would start instantly. The problem was usually after sitting overnight that starting was the issue. Anyone have a similar issue? Now, I am having the issue again, no codes, but starts after three tries. I figure the older injectors are now failing (it has 224K). Could it be anything else?
