Bad ECM?
Griz24
Ottawa
2012 Jetta
Hello,
I been a a repair streak this year. ac compressor, condesor, timing belt, radiator and a whole bunch of others. I think I am having ECM issues now. So a little while ago upon taking the positive battery cable off. It touched the ecm releasing (zapped) stored energy. Since than a few extra codes been showing up. Misfire on 3, crank shaft senor, about 10 total. I just got done with replacing HPFP, injectors, crankshaft senor. Now the car will fire for 1 second and shut off. Have to turn key completely off or it just cranks non stop (or pull ecm relay) in order for it to fire for one second again. Right before i took it down to fix the HPFP it was in limp mode and and had metal shavings in the screen. plus the Transmission was shifting terribly
Now a couple month ago i did something really stupid...... I replaced the intake valve, and egr valve cause i had bad codes on them. the dumb part, i was unaware i had to hook up to vcds and adapt them. so now part of the 10 codes from above are about the soot on DPF filter and such. I have no want to replace them till i can get the car fired back up and running
Any thoughts if the ECM is the issue?
Zakh55
Texas
2014 Jetta CJAA M/T
If the car is starting for 1 or 2 seconds, it could be an immobilizer issue.
If you buy a used ECM, you'll have to send the unit off to have the immobilizer bypassed or deleted by having the chip removed. Kerma offers this service.
A surge to the ECM could fry a trace or ROM chip. You could open the unit and check for burnt areas around the chips.
I would first check all of the outputs on your ECM, but that is a lengthy process.
I don't have a VAG, but I'd check the Ross-Tech forums as well.
Someone else will have better advice than I do.
Griz24
Ottawa
2012 Jetta
I can see how this could be a immobilizer issue, but nothing comes up as security on the dash. I've seen it in the past when I tried to use a key that wasn't programmed correctly. But the car started longer for that. When I get home tonight after work. I'll pull apart the ecm. And post a couple pics
TurboABA
Kitchener, ON
How about you start by posting your full scan so we can see what's going on since it doesn't sound like you know what you're doing with VCDS?
Zakh55
Texas
2014 Jetta CJAA M/T
I'll get that posted tonight. Yes, I'm pretty new to vcds
You can manually test the output, 1 by 1, on the ECM, or VAG can do it.
If you don't have VAG, then you'll have to do them 1 by 1... Lengthy process.
Griz24
Ottawa
2012 Jetta
Monday,29,September,2025,17:35:00:13596
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: 3VWLL7AJ4CM405359 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 77
VIN: 3VWLL7AJ4CM405359 Mileage: 207370km-128853miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 18816 679 460486
VCID: 382EF55FBE50DA0A763-806C
VINID: 0E69DC70745A1137440050C52461F86B71
20 Faults Found:
011174 - NOx Emissions Exceeded
P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:05:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 980.1 mbar
Temperature: 19.8°C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 27.0°C
009315 - Particle Filter
P2463 - 000 - Excessive Soot Accumulation - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:05:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Pressure: -149 mbar
Hex Value: 0xFF01
Temperature: 18.0°C
(no units): 0.0
Mileage: 1650 km
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 01:40:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.46 V
Lambda: 99.4 %
Bin. Bits: 00000000
000135 - Fuel Rail/System Pressure
P0087 - 006 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:14:60
Freeze Frame:
RPM: 1334 /min
Inj. Quantity: 0.0 mg/str
(no units): 4.0
Pressure: 320.0 bar
Pressure: 8.0 bar
Temperature: 16.2°C
Tank Cont.: 52.9 l
P0087 - 004 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:15:01
Freeze Frame:
RPM: 1196 /min
Inj. Quantity: 1.6 mg/str
(no units): 4.0
Pressure: 376.0 bar
Pressure: 8.0 bar
Temperature: 16.2°C
Tank Cont.: 52.9 l
000801 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:18:10
Freeze Frame:
RPM: 46 /min
Speed: 0.0 km/h
Voltage: 11.63 V
Temperature: 20.7°C
Idle Stabilization: 0.0°KW
RPM: 0 /min
(no units): 1.0
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.20.
Time: 01:22:17
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Inj. Quantity: 8.5 mg/str
Mass Air / Rev.: 435.0 mg/str
(no units): 3.88
Temperature: 33.3°C
Temperature: 73.8°C
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.20.
Time: 01:24:53
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.22 V
Voltage: 13.22 V
Voltage: 13.22 V
Voltage: 13.22 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.20.
Time: 01:25:57
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Bin. Bits: 00100010
Torque: -6.0 Nm
Bin. Bits: 00100010
Ign. Timing: 18.4 °ATDC
000611 - Fuel Injector #1 (N30)
P0263 - 002 - Contribution/Balance Fault - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:03:20
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.86 V
Temperature: 22.5°C
Temperature: 18.0°C
Bin. Bits: 0000000
000144 - Valve for Fuel Metering (N290)
P0090 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 19:58:31
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.10 V
Pressure: 0.0 bar
Lambda: 36.3 %
Lambda: 11.0 %
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 000 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 02:24:42
Freeze Frame:
RPM: 276 /min
Speed: 0.0 km/h
Voltage: 9.65 V
Temperature: 18.9°C
Idle Stabilization: 57.1°KW
RPM: 137 /min
(no units): 33.0
000136 - Fuel Rail/System Pressure
P0088 - 003 - Too High
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 02:24:44
Freeze Frame:
RPM: 276 /min
Inj. Quantity: 26.6 mg/str
(no units): 4.0
Pressure: 392.0 bar
Pressure: 1344.0 bar
Temperature: 19.8°C
Tank Cont.: 47.6 l
P0088 - 001 - Too High
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 02:24:48
Freeze Frame:
RPM: 299 /min
(no units): 5.0
Pressure: 400.0 bar
Temperature: 19.8°C
Tank Cont.: 47.6 l
000401 - Fuel Pressure Sensor (G247)
P0191 - 002 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 02:28:18
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Hex Value: 0xFF02
Pressure: 1352.0 bar
Voltage: 11.93 V
Temperature: 18.9°C
Temperature: 20.7°C
008449 - Throttle Valve Actuator Control System
P2101 - 000 - Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.93 V
Lambda: 99.4 %
Bin. Bits: 00000000
008215 - Intake Manifold Flap Position Sensor (Bank 1)
P2017 - 000 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.86 V
Lambda: -2.4 %
Lambda: -7.9 %
Bin. Bits: 00000000
Voltage: 5.016 V
008200 - Intake Manifold Flap; Bank 1
P2008 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:01:48
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 16.2°C
008448 - Throttle Actuator Control Circuit
P2100 - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:06:19
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 0.0 %
Lambda: 99.4 %
Temperature: 16.2°C
001164 - Sensor for Exhaust Flap
P048C - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 00:26:23
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.93 V
Lambda: 3.9 %
Lambda: -11.8 %
Bin. Bits: 00001110
Voltage: 1.216 V
Readiness: 1 6 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001202221651
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 147661EFC278DE6A3AB-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492200FF8D0E02E992220042A71000
VCID: 7DA0244BDDF23F22E55-8028
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000905294
VCID: 6FBC0E038B9E5DB2679-803A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 04371111121140
Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300000000000
Shop #: WSC 29832 003 1048576
VCID: 2F3CCE03471E1DB2279-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Serial number: --------------------
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0004TDM
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0169112
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM05H7LY Dataset Number: 160003v____ 0154
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3436C16FAEB83E6A5AB-8060
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000DNNN09
Coding: 303036
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME3B2A626AZZZ0
Crash sensor for side airbag: passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2450306CZZZQ
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME36000919ZZZH
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME14030919ZZZH
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME20190818ZZZN
Crash sensor for front airbag: passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME65285F17ZZZ1
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00123
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2908201B797A7382F9D-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70BE0D7F9AA0424A7E3-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0604
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8A1F17BCFCB89A307-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661566232
Coding: 010000
VCID: 2908201B79FA7382F9D-807C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372CF663B34ED5727F9-8062
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0013282 Dataset Number: 560050v____ 1604
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 65906C2B55E297E21D5-8030
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3285468
Coding: 01020000010006
VCID: 639472335B56E9D2F31-8036
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 19
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.20.
Time: 05:08:43
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661967564 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270C26236F6E45F2EF9-8072
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.5V)-----------
------------------------------21 Faults Found------------------------------
TurboABA
Kitchener, ON
Validate timing!
Fix this first.
The ECU needs RPM signal in order to know how to do anything, especially when just about everything else is also broken.
Griz24
Ottawa
2012 Jetta
Validate timing!
Fix this first.
Just replaced the speed sensor, along with crank sensor
Am I using the correct timing kit? 2012 Jetta TDI. I feel like it isn't. But it's what I been using
Zakh55
Texas
2014 Jetta CJAA M/T
What Turbo said; replace G28 first. It's easy to get to.
If you've ever replaced your oil cooler or the oil cooler seal, then you basically already know how to do this job.
It's right next to it.
Griz24
Ottawa
2012 Jetta
Yes, I just replaced that. Even replaced the connector. Yes I twisted the wires like the original one. Isn't that sensor tied to the RPM gauge? Cause I'm still getting the rpms showing up on gauge when cranking and when it starts.
Zakh55
Texas
2014 Jetta CJAA M/T
It's the RPM sensor, yes. It's the easier of the two to fix. Run your VCDS again, check and see if it's getting signal, and then move on to the next one.
Griz24
Ottawa
2012 Jetta
newest scan after the timing redone
Saturday,04,October,2025,19:17:30:13596
www.Ross-Tech.com
56-Radio -- Status: Malfunction 0010
Coding: 0050078
20 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:05:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Temperature: 19.8°C
Temperature: 27.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:05:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Pressure: -149 mbar
Hex Value: 0xFF01
Temperature: 18.0°C
(no units): 0.0
Mileage: 1650 km
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 01:40:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.46 V
Lambda: 99.4 %
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:18:10
Freeze Frame:
RPM: 46 /min
Speed: 0.0 km/h
Voltage: 11.63 V
Temperature: 20.7°C
RPM: 0 /min
(no units): 1.0
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.25.
Time: 01:22:17
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
(no units): 3.88
Temperature: 33.3°C
Temperature: 73.8°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.25.
Time: 01:24:53
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.22 V
Voltage: 13.22 V
Voltage: 13.22 V
Voltage: 13.22 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207280 km
Time Indication: 0
Date: 2020.02.25.
Time: 01:25:57
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Bin. Bits: 00100010
Torque: -6.0 Nm
Bin. Bits: 00100010
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:03:20
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.86 V
Temperature: 22.5°C
Temperature: 18.0°C
Bin. Bits: 0000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 19:58:31
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.10 V
Pressure: 0.0 bar
Lambda: 36.3 %
Lambda: 11.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 02:24:42
Freeze Frame:
RPM: 276 /min
Speed: 0.0 km/h
Voltage: 9.65 V
Temperature: 18.9°C
RPM: 137 /min
(no units): 33.0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 02:24:44
Freeze Frame:
RPM: 276 /min
(no units): 4.0
Pressure: 392.0 bar
Temperature: 19.8°C
Tank Cont.: 47.6 l
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 02:24:48
Freeze Frame:
RPM: 299 /min
(no units): 5.0
Pressure: 400.0 bar
Temperature: 19.8°C
Tank Cont.: 47.6 l
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 02:28:18
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Hex Value: 0xFF02
Voltage: 11.93 V
Temperature: 18.9°C
Temperature: 20.7°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.93 V
Lambda: 99.4 %
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 05:18:15
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.86 V
Lambda: -2.4 %
Lambda: -7.9 %
Bin. Bits: 00000000
Voltage: 5.016 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 05:18:17
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Temperature: 16.2°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:06:19
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 0.0 %
Lambda: 99.4 %
Temperature: 16.2°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:26:23
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.93 V
Lambda: 3.9 %
Lambda: -11.8 %
Bin. Bits: 00001110
Voltage: 1.216 V
001029 - EGR Sensor 1
P0405 - 000 - Signal too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.16 V
Lambda: 99.4 %
Lambda: -2.4 %
Voltage: 0.000 V
Bin. Bits: 00000000
005184 - EGR Valve (N18)
P1440 - 000 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 06:45:04
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Temperature: 18.9°C
Coding: 0000020
Revision: 00H31001
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 020000
Coding: 800000
Coding: 800000
Coding: 00003936
Coding: 303036
Coding: 270A01
Revision: B2066001
Coding: 102200
Serial number:
Coding: 000000
Coding: 010000
Revision: 00H22000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 19
Mileage: 207375 km
Time Indication: 0
Date: 2020.02.25.
Time: 05:08:43
ROD: UHVNA.rod
End----------(Elapsed Time: 01:28, VBatt start/end: 12.4V/12.4V)-----------
TurboABA
Kitchener, ON
Did you not clear the DTCs after your fix? Why is that same code still there?
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 207277 km
Time Indication: 0
Date: 2020.02.25.
Time: 00:18:10
Griz24
Ottawa
2012 Jetta
Yes. I'm stumped. Is there a way to check (aside from visually). For passable wire harness problems? I'm gonna start a post on that specific issue see what reply I can get.
So been reading, bad alternator can cause speed sensor issues, what's your thoughts on that? Currently I'm keeping the battery charged from the cranking by connecting it to my solar bank. It keeps it at 13.6 on a constant regardless how drained the bank is. (Diodes are involved). Thoughts on the alternator?
TurboABA
Kitchener, ON
So IF you did clear the DTCs after your alleged fix, then the fix didn't solve anything.
Did you check wiring integrity between your fixed connection and the ECU plug? Run on overlay to bypass the harness?
Did you log the signal during cranking?
TurboABA
Kitchener, ON
I don't like using the parts cannon as it gets spendy quite fast... but it would appear that you do, so go for it, throw an alternator at it.... it's still not going to start without RPM signal.
Griz24
Ottawa
2012 Jetta
There was one spot that was questionable on the wiring harness. But was after the connection. Behind the oil filter, was vibrating enough to rub off all wrap. No visual issues with wire though. I put layer of felt and wrapped it up with heat automotive tape. Is there a way to test the wires beyond visually inspection. I keep seeing "use a voltmeter". But no steps on how.
I will hook it up tonight and get you the stats on cranking.
Griz24
Ottawa
2012 Jetta
Man I really appreciate your help, I do. I know how to use a voltmeter, but my biggest problem is. There is three wires. What are the wires purpose, one ground? I am guessing one is continuous power, and one sends the signal back, but which is which??
So I'm not trying to be rude here. I don't live breath and eat TDI knowledge. This is my first car outside of owning trucks and foreign (all diesels btw) and I can fix them no problem. But if you were asking me questions in areas I excell at, I certainly wouldn't be posting smart ass ****. Again. Appreciate the help, but not everyone is as good as the next guy. Now if I was asking what the colors of the battery cables mean, than by all means. Post away ..
I guess your google is broken too :rolleyes:
TurboABA
Kitchener, ON
You need wiring diagrams so that you know where the wires go to. (read what ECU pins, etc)
Your first check it to make sure the wires aren't broken, especially from rubbing onto stuff
and that they have continuity and can carry current....
The wiring diagrams will also (more than likely) tell you where you can expect power, ground, etc. So armed with all that info, and the multimeter, you can validate the "harness". Now, if you can't validate it, you can easily run an overlay just to ensure that your new sensor & connector are fully functional and you get RPM signal.
So, is it safe to assume that you don't have Wiring Diagrams and are kind of just poking around in the dark at this stage? :unsure:
Griz24
Ottawa
2012 Jetta
Got one off Erwin website. Played around looking a bunch of things up while at work today. That is gonna be my next task with the car. Figuring the locations of those wires. Even if I have to temporarily jump them straight to the connector by bypassing the whole wire harness. I will do just that.
TurboABA
Kitchener, ON
That's good... Now you know what pins at the sensor correspond with ECU pins so you can check wire continuity for starters.
