BearForceOne
Hey all, I've been driving my '01 Jetta for about two months now mostly trouble free. It's at 346k miles and runs like a champ, save for burning some oil. I've noticed, since I began driving it, whenever I start from a stop and let the clutch out, the car shakes pretty noticeably until the clutch is fully engaged and the car is in motion. There is also a bit of shake I can feel in the pedal with it fully depressed. All other shifts are perfectly fine without incident and it's driven fine, until today.
On my 30 mile commute, almost every time I tried to start from a complete stop in first, the engine would stall. I noticed the clutch didn't feel like it was grabbing at all like it was before, the car would barely creep forward, and no matter how slowly I let off the clutch or how much fuel I gave it, it would almost always stall. I ended up having to start in second to get it home, which is less than optimal. I also noticed it is much harder to get into first from neutral, needing returned to neutral and aggressively pushed into first.
I know the characteristic symptom of a failing DMF is a clatter coming from the transmission, which I don't hear at all. However I can't figure anything else that would cause these issues, and assuming it's the original flywheel I wouldn't be surprised if it went at 346k miles. The transmission definitely feels its age and the synchro for first gear isn't it good shape (I have to depress the clutch and hold it for a moment before putting the transmission in first, otherwise it grinds), however I don't think it's a transmission issue.
Has anyone experienced something similar to this when their DMF has failed, or maybe has some other input or suggestions? I would greatly appreciate it, as this is my daily driver and I need it back on the road ASAP.
Thank you!
Thank you!
