PRY4SNO
Anyone know if it would be possible to retrofit the backup camera that's hidden behind the VW emblem like on 2015+ Golfs?
You need to read between the lines. He has a Touareg, but doesn't like the OEM reverse camera (most likely because it gets dirty and becomes useless unless you're driving in clear conditions all the time), and he wants to replace it instead with the "flip emblem\hidden" version as a retrofit.Give the Golf sight a shout out.This is the Touareg area,
Try to catch up, that's already been pointed out elsewhere in less time. I'm sure you can add value here next time, if you try.One of us needs their eyes checked.... because that is NOT a 7P Touareg!
That's also too low and too long.... looks more like a Passat Alltrak or something!
How the EFF can you even say that's the same vehicle as you drive? Have you ever looked at your vehicle?
