VWSHPFRMN
I have been asked by several members to explain the fuel lines on the B7 TDI engine. There is no longer a return to the tank from the filter. The boost pump has been eliminated. Fuel is supplied from the tank to the filter. From the filter the fuel is supplied directly to the HPFP. From the HPFP fuel is supplied to the fuel rail. From the rail fuel is supplied to each injector. Fuel return goes as follows. From the fuel rail unused fuel is retuned to the fuel filter. From the HPFP and the injectors unused fuel is returned directly to the tank. It is my belief that the hot fuel from the rail is returned to the filter to heat the fuel.
