B6 S4 bhw compound turbo build
Machineman
ontario canada
2007 RS4 Titanium 3.0TDI & 2013 Touareg TDI & B6 S4 BHW Swap Biturbo
Pre iat thermocouple i wanna know the ic eff%
Machineman
ontario canada
4 bar map wont cut it for this application so i chose to run a 5v pressure transducer 7bar and the post iat sensor was dismantled and i soldered the ntc from a factory map sensor to avoid scaling issues oem ntc is 2.2k ohm at room temp delphi was 3.5k
Machineman
ontario canada
Intercooler and pipe work is all done i have to finish the rear section of exhaust and go for test drive :)
Bambaataa
KW, On
06 Jetta BRM 6MT; '15 Golf Sportwagen TDI GSW
Very Cool Build.
Looks amazing!! Can't wait to see numbers from a dyno...
Subscribed!
Celco
Warren, MI 48092
2002 Golf 4dr ALH 5-speed
Oil pressure sending unit tee fitting
What oil pressure sender unit are you using? And what is it going to? Going to run a homebrew arduino, new south/52mm analog gauge, or something autometer?
I have a New South Performance gauge that I would like to use in my car, but that sender unit is CRAZY big.
Good looking build!
Machineman
ontario canada
I'm running VFIZ it is a box the taps into the cluster displays everything over the MFA screen via canbus or obd very slick a guy in poland makes them these also have external inputs for common sensors mine being 0-5v
Machineman
ontario canada
Can anyone comment whether I should powdercoat the intercooler piping black or leave it stainless ? Im on the fence
bhodgkiss
Banbury, UK
AFN Passat Wagon
Might be a stupid question, but if fabbing all your own pipes and exhaust, why not use titanium for the weight save?
Much more expensive and harder to weld I presume? You could use motorcycle type silencers in Ti?
I'm sure there's a pretty obvious answer!
QuickTD
SW Ontario
2003 Audi A4Q 5spd 2.0 TDI 2056VK R783, 2006 Audi A4Q 6spd 2.0 TDI
Aluminum is lighter than Ti and can be used for IC piping. Tricky to weld in thin sections though. Stainless is fairly easy to work with, welds easily in thin sections and is readily available for reasonable money.
Not easy to find titanium, expensive, mandrel bends are very hard to find and very expensive, must be welded in an atmosphere of argon (glove box) or at very least back-purged or it will crack, also it's expensive. Did I mention it was expensive? Better to save the 5 pounds by throwing out the jack...
I don't think silencers were much of an issue for Machineman, his are pretty light already...
Machineman
ontario canada
Sounds about right! Titanium is available from vibrant performance the cost is astronomical and yeah my spare tire is gone that's 50lbs alone and its free
[486]
MN
02 golf ALH
Ti is actually twice the density of alu, the only advantage it has over alu is at high temperatures it retains its strength where aluminium gets very brittle
if he was running 500+ degree compressor outlet temps for minutes on end then it would be a consideration, but as said, stainless is cheaper by far, not to mention the welding troubles. Kind of like alu vs magnesium.
Why not aluminum exhaust past the downpipe? seems to work for my junk :p
I'd leave the piping bare. Those are welds to be proud of from the pics up there.
TDIMeister
Canada
Ti is actually only about 66% higher density, not 2X. Aluminum is not usually used for the tail-end of exhausts because of acid corrosion attack from exhaust gas condensate, but its a matter of degree, as mild steel will also corrode exposed to the same conditions. Nothing wrong with it really, except for maybe having to join dissimilar metals at some point and the resulting galvanic corrosion. Edit: Anodizing the aluminum should help corrosion resistance, though.
If we consider carbon fibre tubing, now we're talking!
Machineman
ontario canada
I had the car last night for a drive it pulls very well the center driveshaft hangar cannot handle power it shudders a lot Under full Boost
adamss24
Great Britain
Its to be expected especially if the prop bearing is worn... Get a replacement snd see if it improves results otherwise you need to limit the torque low down the revs!
Lucian189
Romania
3.0 TDI CR
Again a nice thread and nice info.!
Cant beliewe you took the 4.2 out
Trimis de pe al meu SM-J510FN folosind Tapatalk
adamss24
Great Britain
Actually the s4 v8 lump is troublesome and all have problems with timing chain stretching and throwing many fault codes and Then the car goes in
limp mode... in severe cases bending valves is also common ! I personally had an s4 and whilst fun to drive on a weekend- it was rather a thirsty beast ! I reckon it will go really well with a full blown Diesel engine- it won’t sound as the v8 but less maintenance issues !
