Machineman
- Joined
- Aug 25, 2014
- Location
- ontario canada
- TDI
- 2007 RS4 Titanium 3.0TDI & 2013 Touareg TDI & B6 S4 BHW Swap Biturbo
Finally got a chance to post I thread about my build this is one of the few compound turbo build in a longitudinal setup running on the street I took a slightly different approach for Turbo placement which ended up being a very good success I'm running a tdo4 13t high pressure Turbo had a TD06 20g low pressure which is mounted to the tranny with a ultragate38 wastegate almost everything is been custom manufactured schedule 40 manifold with also a schedule 40 hot pipe the car has a Stage 5 South Bend clutch 240mm and I will be running firad160 nozzles power goals are kind of unknown at this point I have about 900 CFM of air to play with so we'll see where that takes me I'm guessing somewhere around 350 awhp would be acceptable very excited to get this going as I've never done a street driven compound setup and I have ran the tdo4 as a single before and it's very responsive so as compounds that should be very good .
