B5 manual shifter linkage upgrades
bbob203
Louisville, ky
b5.5v
Doing some window shopping for the b5 I'm probably getting soon. Wondering if anyone w/ the 5 speed swapped cars have done any kind of upgrades as far to the bushings for the 5 speed linkages. The car is an auto 1.8t but will be getting an AFN and 5 speed not much longer after I get it so I will replace things like the shifter bushings while it is out. This is the only real kit i have found but its almost 400 bucks..
http://jhmotorsports.com/shop/catal...ng-for-1998-1999-b5-a4-passat-early-p-64.html
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d
Note that the kit only covers later 97-99.5 Passats as the shift linkage was vastly improved in late 99. Get a linkage from a 2000 up car and you will be fine. Those early ones makes it feel like you have a 3' throw and that you are guessing at the selection. VW also dumped the push down for reverse feature in the later models as well.
Also 2000 and early 2001's had screw on knobs while later ones used a crimp to hold them tight. I prefer the screw on type
jonlowe
Northern AL
2005 Passat GLS Wagon, 5 speed conversion, GBSM
I got a shifter with a screw on knob from him. The linkage is very precise, and I haven't seen any need for improvement.
Jon
50harleyrider
charleston,wv
2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
bbob203
Louisville, ky
b5.5v
TheDude
Sweden
VW Passat 1.9TDI Syncro -99 (AFN)
Hello!
I know that this is an old thread, but I´m asking here instead of creating a new thread..
My Passat from 1999 suffers with really sloppy shifting.
Or maybe I am suffering the most about it. ;)
So it would be best to buy a shift linkage from a newer model?
I guess they are just plug and play?
I have an Audi A6 from 2003 with the same mileage, and it is a really big difference.
Is it #15 on this parts page I am searching for?
Parts list
I guess the rods #37 and #28 don´t wear? or maybe some bushing on them?
Look at my shifter here, this is with a gear in... :)
Gear linkage
vwztips
Greenville, SC
The rods are the same . All the slop is in the shifter mechanism
TheDude
Sweden
Thanks!
I will try to find a low mileage 8D0711055AE, new ones seems hard to find.. :)
Too bad I already replaced the gearstick boot, it seems to be crimp instead of the screw on..
TheDude
Sweden
I have found one now, but without gearstick boot with 90000km, like new..
Is it possible to move over from my old stick, with the screw one type, to the crimp/clamp type? Guess not...?
