Tires pulling
I don't know what brand/size tires you folks have on your Passats, but mine are the Continentals, 205-16, IIRC. I noticed the car start pulling to the right at first rotation. When I rotated them back, the pull disappeared. I've had this happen with other cars/tires in the past and it's most likely caused by a slight belt shift or wear in one of the tires, and occasionally more than one. It's called radial tire pull and usually isn't a really hard or radical pull, but just a bothersome, gentle sort of nuisance pull. Also, while I dislike pulling either side of straight ahead, I'd much rather have a pull to the right...if I ever fell asleep at the wheel
, heaven forbid, I'd want to be heading for the ditch rather than head-on traffic!
Anyway, my Goodyear dealer here in Broken Arrow, who has been really good to me for the last 20 years and who I definitely trust on tire stuff, has shared all sorts of reasons for radial tire pull. So, it can be who knows what that actually causes it. However, it wouldn't surprise me in the least if, on a brand new vehicle with brand new tires, that the initial breaking in/driving especially with a front wheel drive, could well cause a little uneven strain on the belts on the side receiving most of the torque, thereby causing a slight belt shift, and resulting pull.
Hope this explanation is of some help. You might try rotating them back to the previous positions or (and I know VW doesn't recommend this, but it doesn't really hurt the tires in any way) swap the two fronts from side to side and see if the pull doesn't go away. Many tire manufacturers recommend rotating tires from front to rear on same side, then X-ing right rear to left front & left rear to right front for this very pulling reason. Might be worth a try
