B5 bhw wiring harness stand-alone
Jazz_3b
OH
05 vw passat 2.0 tdi
Hey guys i need help with cab side wiring harness stand-alone build from what I can tell all I need is brown wire, black wire, black and blue wire, red wire am I missing anything
Runninwild
vancouver
AAZ swapped 2000 tacoma
Would also be interested in the engine side of things if anyone has the info to share. An ecu pinout or an easy way to figure that out would be idel
Straypoet
Florida
BHW 2.0, soon to be in my Wrangler.
I will be re-doing my BHW harness over the next month or so, I might be able to help. I am planning on doing a few videos on my swap including the harness work.
tims944
montreal quebec
2015 Golf Sportwagen TDI, 2006 mk5 tdi-SOLD 1989 944 s2 BHW swapped
I can get you any diagrams for the car you need send me a pm with what you want and the model etc.
Its how i took my b5.5 harness apart for my bhw build
Straypoet
Florida
Thank you, I can use that as well, PM incoming!
supertom7
Bokeelia, Fl
none
Hi. I'm working on a BHW harness and need help. going to swap into my '90 Toyota/Winnebago RV Would appreciate any diagrams. I hope to use the original Passat display. Later Tony Moors clemtony@juno.com Bokeelia, Fl
