0die
Update time....heavy duty rear B4V Passat wagon springs.
got my new HD euro spec springs installed
Monroe SP0495 springs, listed as HD (heavy duty) for Estate (wagon).
Obtained from Amazon UK site
. Google search "Monroe SP0495" and Amazon UK is top hit. Rock Auto second hit but they will cancel your order after you place it
UK Amazon seller often lists "temporarily out of stock" or "only one left"
. Go ahead and order 2 springs anyway. It will ship when back in stock. Took about 3 weeks from back ordered to my door step
. Total $177 US delivered (tax, shipping, everything)
side by side comparision with OEM US wagon springs...they look identical in height and coil design. OEM about .512" coil diameter. Monroe about .540" dia. with my micrometer...or there abouts///
After install the rear height rose about 1-1/4". Driving a little bit it looks to have settled around 1" to 1-1/8".
I replaced the strut mounts too but the old ones were perfectly fine. But I already bought new mounts so in they went. New boots too (mine were long gone). And new Bilstein TC struts. But the OEM Boge struts still had good gas charge on both sides. I could have just used the old struts and mounts and been fine. But I already spent the money.
all in all...about $400 total spent on everything (springs, struts, mounts, boots).
but to finally answer the wagon spring question...yes, heavy duty springs are readily available and they do raise the back end.
