thechoochlyman
Who has installed a VNT in their B4? Looks like it would be quite an undertaking considering the intake, exhaust, and charge pipes are all different. I'd like to go with an 1856v or at least a 1752.
if it were me, i would do the modified motor mount bracket and get a GTD - powertdi will make one that will fit, with GTD welded onto whatever manifold he uses for that. i previously orderd a gtd2060vz thinking it might fit "as is" but with compressor outlet welded more straight-out like a vnt15, but unfortunately it didn't come close to fitting even with the aftermarket motor mount. but then i talked to him and he said they will make any of their turbos fit if you specify which chassis... so i'll be saving this 2060 i have for another car, and i ordered another, this time specifically saying for my mk3. hopefully should have it in a week or two and will take pics and test fit it.I just pulled the trigger on an AFN exhaust manifold - seems like it'll make things go easier without having to modify the engine mount.
Now I'm getting really lost in the weeds with all of Garrett's crazy numbers and letters. Apparently the GT1749V is smaller than the GT1749VA GT1749VB, all of which correspond with the PD100, PD130, and PD150 respectively. I put out a feeler in the buy and sell forum for a used GT156V or BV43, but I only know for sure the latter of which should bolt up to an AFN manifold (at least, the one that Cascade German sells).
Ugh. I just want something relatively inexpensive to buy used that will perform a ton better than my GT15 - which I feel like is pretty much anything else. What do you think, Guthrie?
Was stock on BHW, I believe. Could be on others. It is the Borg Warner equivalent of a GT1749VA. It was the stock turbo on PD130s in Europe.Great info there, thanks! Looks like the BV39 was stock on a BRM?
Ah, makes sense. Throwing in all the Borg Warner turbo models makes it seem more complicated, but it's basically the equivalent of the K03 vs GT15.Was stock on BHW, I believe. Could be on others. It is the Borg Warner equivalent of a GT1749VA. It was the stock turbo on PD130s in Europe.
That's the same manifold as the BHW except that BHW has a probe port already drilled and tapped, no need to go to Europe for that.AFN manifold showed up from Europe today. Also have a GT1749VA coming from a guy in Canada.
Well, the same inlet pipe would bolt onto it - but I'm sure it won't be clocked in the right position relative to the engine and accordion hose. Luckily I have another inlet pipe that has broken ears, so I'll be able to bolt everything up to my parts engine and epoxy it onto my flange at the right angle to meet the accordion hose. At least, that's what I'm planning on. hahaIs the inlet pipe bolt pattern clocked the same way to the compressor outlet on both the VNT17 and the old GT15? Very handy if that’s the case!
Not gonna lie, I did consider it but it seems like there are a lot of options already out there. What about the ones from ECS tuning? I could probably try to make them for around $80-$100.All the “VNT17” compressor outlet adaptors on the market don’t seem to fit or fit poorly to where they leak boost. It would be amazing if you could start making those. @thechoochlyman
yup. seen many of those leak. boost leaks drive me nuts with tuning.. eveyrone swears they don't have any... until they actually look at every connection very closely or pressure testAll the “VNT17” compressor outlet adaptors on the market don’t seem to fit or fit poorly to where they leak boost. It would be amazing if you could start making those. @thechoochlyman
I'm not too concerned about it... I'm sure it'll be blowing boots off before those bolts snap. lolThat's a neat design.
I'm not sure how strong that little M3 bolt is in shear, though.
