Andrei Rinea
- Joined
- Jan 21, 2002
- Location
- Europe, Romania, Bucharest
- TDI
- VW Tiguan 4Motion 2.0 TDI 170HP (engine CBBB)
I feel your pain... had many troubles with my TDI (B4 Passat 1Z engine 83kmiles) and had times when I only thought: "You stupid #@O$Y*(@#$@#&$@#$ @%#*YY*%@*(%@#*(%@#%@# $%@#*$)*(#@$ car! I am gonna sell you next day"
But then I pulled myself together again and troubles didn't have the guts to show up again... small problems like fried bulbs or stuff like that.. worn bearings... nothing serious... except jumping timing belt due to serious engine design fault but fixed it for good.
BOTTOM LINE: Pull yourself together and fight it!
About the specific problem:
The engine moving during throttle doesn't hurt any such pipes as the injection pump is mounted on the engine and moves along with him.
Check the injection pump at a good service not stealerships which suck all over the world (Romania, USA, Canada, Belgium and so on).
Could also be the injector #3 end the one which can cause the high pressure pipe to crack?
Check other moving parts (hood? I doubt but...) that could hit the pipe...
That's all I can "help" you with...
GOOD LUCK and keep us posted as it goes
