Changed the timing belt, manually adjusted timing to 2=66 and 9=107 in basic settings. Car runs great. However in basic settings block 004 specified start of inj toggles between late and early. When late actual start =3.7 and when early actual start=7.7. Spec is between 2 and -3. If I look at start of injection in measuring blocks both specified start of injection and actual start are 2.6. I had cam, flywheel and inj pump at TDC, what did I screw up? Is my injection pump going bad?
