ssnick
I've done a lot of research on this problem and haven't found symptoms similar to mine. I have a 97 Passat that I run with biodiesel that developed a noticeable turbo whine and smoking problem after a long drive where I pushed it harder than usual. I pulled the turbo and found that it was indeed toasted and replaced it with a used one that had very little play. It did have two slightly bent compressor blades (Opposite each other) however, it didn't seem to be enough to cause problems.
I started it up last night and at first it seemed fine. Although I did still hear a whine I assumed it was because it didn't have enough oil pumping through it yet. I had added oil to the turbo's oil intake connection but due to the fuel pump loosing it's prime, it took a while of turning it over to get it to start and I wasn't sure if oil was getting to the turbo during that time.
It ran well and revved well but as I said, still had a turbo whine. I drove it around the block and after about 2 blocks noticed that it was now smoking a little. Gave it some gas and it smoked more. By the time I got back home, it was smoking a steady stream of a whitish smoke.
Checked the coolant and it was fine, noticed there was bubbles in the fuel line although I had that before.
Went to bed sad. Started it this morning. No smoke, easy start, now no whine. Happy! 2 blocks down the road, starts smoking and turbo whines when spooling. Sad again.
I initially thought that the new (Old) turbo was also bad, but started thinking that it might be something else or a combination of things.
Bent compressor blades and bad bearing, oil starved turbo, bubbles in fuel, fuel injector issues...?
Sound familar to anyone? Any ideas?
Nick
Nick
