ebernhoft
So here is the Saga: My window started making this horrible noise when it reached the top of the track. I was suspicious of the window regulator as outlined in the myturbodiesel.com article (below):
http://www.myturbodiesel.com/1000q/a3b4/window-power-repair-regulator.htm
I removed the regulator and indeed two of the teeth where the regulator meets the motor were completely rounded off. It was replaced with a mint looking junkyard regulator. It now no longer makes horrid noises. I noticed at the time of replacement that the circular plastic nob that is used for adjustment was somewhat mauled on the old regulator, as if the motor was being too forceful. I adjusted the new regulator with the new nob, however, it seemed to bite into the plastic and the regulator looks to end up in the same configuration that it did without the nob at all.
Anyways, I also noticed that despite adjustment when the window rolled up all the way the door frame flexes slightly. It seems that the other windows do not do this. I have begun to notice that the same teeth on the new regulator are starting to show wear and tear. This again seems to indicate to me that the motor itself is exerting too much pressure on the regulator itself. Unfortunately the window motors are OUTRAGEOUSLY expensive even from the junkyard ($140 used).
Does anyone have any thoughts or advice? It is sorely needed. Thanks
New motor? Reset pinch protection? Fabricate a more durable oval, plastic, configuration nob that doesnt get bitten into?
