therabbittree
Ok another ?... I have '96 passat wagon with the BK ECU. I have replaced the N75 valve, checked & replaced the vacuum lines to waste gate and N75 valve and ecu. Removed EGR, Replaced intake and de-gunked the Cylinder head. CCV Vented, New T-belt, new fuel filter, Timing set correctly, no muffler, no extra fuel injectors in exhaust, and kerma power plus 216s, There is no trouble code for MAF.
The problem is the car has LOW power. It is so slow I believe a NA early rabbit is faster. The car only peaks at 8-10 psi boost..most of the time only 6 psi,if you load it -it will fall on its face, its like it cuts the fuel off. it is non responsive to throttle pedal input..if you let off for a second or so it will regain power and pull till does it again in a few seconds. The EGTs top out 1200 or so pre turbo. I tried swapping in the stock injectors agian to try that, and it was SOOOO SLOW.... REALLY REALLY BAD...so back in with 216 pp's...I even tried to get a upsolute chip for it, but they couldn't get the ECU to accept the right program for the 216 injectors..they thought the BK ecu was the problem or the MAF...any one have any IDEAS...????? I need to get it to run like my 2001 does..this car only has 60,000 miles so it should be quicker... Any IDEAS?
Deo
\x/ Hillfolk
Deo
\x/ Hillfolk
