My GP fuse was burnt out in my 96 Passat so I decided to replace everything. I got the kit from idparts all went smooth, until that is I turned the key. There is a black wire going from the key cylinder to the fuse block (ground wire?) went up in smoke and burned off all the covering. Took out the new relay that they sent and it had no resemblance to the old. I lost power to fuses 13-18. Checked the other relays one by one pulling them out to bench test and they are all good... Anybody have an idea where to go? We spent about 3 hours chasing wires reading pin outs and searching the inter webs with no answer. I plan to call idparts tomorrow and find out wth they sent me.
Edit- a 97 GP relay was put into a 96 car... What would blow because of that and cause the issues above?
