Does your B4 Passat have the factory Premium radio, but the LCD backlights are burned out?? Here is how you fix that annoying problem. The two bulbs that light the LCD are under the LCD on the back of the face plate. They are soldered onto the board that holds the LCD. First get two of these and remove the radio. Before you remove the radio make sure you have the radios code, because when you take it out you will kill the power to it and the radio will be in the safe mode when you put it back in:
Dimensions of the key below courtesy of Wypij. Thank you.
The keys slide into the radio as shown here. You need one for each side:
After you insert the keys pull the radio straight out. After the radio wires are disconnected and the radio has been removed you have to remove the face plate. You get a screw driver and insert it behind the face plate as shown and gently pry the face off. It is just snapped on. No screws have to be removed. When you pull the face plate off the volume control knob will pop off, so make sure you catch it so you don't lose it.
This is the back of the face plate. This is where the bulbs are. You have to remove the board from the back of the face plate. Remove the 6 screws as shown.
This is a picture of tabs you have to straighten to get the LCD off. The bulbs are hidden under it:
This is a shot of the LCD coming off the board:
After you pull the LCD completely off there are two bulbs, one on each side of the board as shown:
You have to remove the bulbs from the board, first you have to get them out of the green holder that they are in. You can just pull up on the holder. It feels like it is made from silicone or similar material. You won't hurt it. It is really soft.
This is a shot of the bulb pulled up and the holder removed:
You can buy the bulbs that fit this board at Radio Shack. The bulb number I used is 272-1092 Radio Shack stock number #7219. They are 12v, 60ma lamps, two to a pack $1.29. This is a shot of the board with the LCD removed. After you solder new bulbs in you put the LCD back on the board, bend the tabs that hold it to the board and reassemble the radio opposite the way you took it apart.
The only part of the job that is difficult is the soldering of the new bulbs. They are small and you need some patience and a little soldering skill to do it.
Ray
Ray
