Farmboy
- Joined
- Jul 29, 1999
- Location
- Bloomington (Minneapolis), MN, USA
- TDI
- '15 Golf SE TDI 6spd 109k miles; '00 A4 NB 5spd 216k; '96 B4 Passat Sedan 220k
Bentley Picture N94-0025, Section W 94-13 thru W 94-16
Number 13 Contact Ring
Number 16 Clamping washer
What function do these parts serve?
What problems would you expect if they were absent?
Why? Because they are missing on my B4 and there has apparently been a long-standing short from my wiper switch to the lock housing across a space these are apparently supposed to fill. Now I know why I was losing a wiper fuse every so often . . .
Last Friday, the car developed unpredictable, intermittent, total electrical loss when (1) key turns to start position (found out by trying to start car) and (2) when lugged badly (found out quite unintentionally).
After reading and reviewing here and on Vortex and in my Bentley, and trying to figure out where the elctrons were getting lost, I decided to replace the ignition switch to isolate cause, since the battery cables were tight, and when the car wasn't acting up, it was 100% normal (started fine, seemed to have normal electrical power, etc.).
I've had the car for 3 years. While tearing the column apart, I could tell I wasn't the first person to do so due initially to witness marks, and due to missing parts ultimately. Someone else either didn't realize they didn't put the parts back in, or didn't think it mattered . . .
I've reassembled the column, with new igntion switch, new wiper switch, wiper fuse deleted until I know the situation with the missing parts and understand the short that was happening, hoping to at least have a car to drive when it's not raining or snowing, but no luck for now, starter still won't engage & no dash lights. Time for bed, will have to play swap Relay 109 tomorrow, since I have a couple spares I can try . . .
Thanks in advance
CORRECTING EDIT: Missing parts aren't really missing. Apparently, not all parts listed in drawing were installed on US spec cars. Further comment in later post.
Thanks in advance
