Hi Guys
In addition to Derek's information some parts of the Elmos Pinout are known meanwhile
You can find the information in the
German Eurovan wiki
I'll try to give a short translation:
The orientation of the pins is not quite usual as you can see in the article (I cannot link the picture)
Depenting on the Elmos version, marking for Pin 1 is either directly above Pin 1 or in the corner between pin 6 and 7
Pin | Connection | comment |
1 | +5V output (1. regulator) | for controller, display,... |
4 | Ground | |
5 | Ground | |
7 | Sense | If it drops below 7 volts, Pin 12 and 13 become high |
12 | Power-Good-Signal | |
13 | Reset-output | Reset of microcontroller |
23 | +5V Output (2. regulator) | Stepper-motor (?) |
28 | +5V Output (2. regulator) | Stepper-motor (?) |
33 | +5V Output (2. regulator) | Stepper-motor (?) |
38 | +5V Output (2. regulator) | Stepper-motor (?) |
43 | +12v ignition | for 2. regulator |
44 | +12v steady | for 1. regulator |
I will add new information to this article, if there are any news
If you have any suggestions or questions, feel free to contact me
Best regards from northern Germany
Alex
