TDI Jim
- Joined
- Jul 10, 2006
- Location
- Gaithersburg, Maryland
- TDI
- 1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
My 1996 B4V is having a central locking problem. From the driver's side door handle, it will unlock the other 3 doors, but not the Driver's door. Then in about 2 seconds, it re-locks the other 3 doors. When I try to unlock the doors from the front passenger door, it does the same thing, but it does unlock the front passenger door for the 2 seconds before it re-locks all 4 doors. The vacuum pump is cycling the normal time, so I do not suspect a leak. I do think the driver's front door lock actuator is not working as I cannot manually pull up on the lock knob, but can do so with the passenger lock knobs (to allow me to get out of the car)! History:
I just replaced the door latch on the side of the driver's door 2 months ago with OEM VW. The door handle is original, so was thinking of replacing it and the the lock actuator. That being said, I cannot get the driver's door unlocked to be able to remove the inside panel to replace the actuator or door handle so need help with that as well, thanks guys!
