cal327
I have a long list of parts I am looking to get out of my basement, I had a b4 passat for years and acquired quite a collection. I am now driving a mk3 amongst other cars and do not need the stuff.
B4 BEIGE INTERIOR
I have an almost complete beige interior. I converted mine to black. I should have everything except A-pillar trim. This is free to a good home, local pickup at zip code 19943. I would consider meeting within a reasonable distance, but prefer it to be picked up.
B4 WINDOW REGULATORS
I have an assortment of b3 and b4 window regulators, the regulator is basically the same. The motors are different, but they interchange. Some have been welded on and teeth reground into them. I think I have one full set and a couple odd ones. $100 asking.
1996 ONLY FUEL LINES
I have a set of fuel lines that fit the 96 passat with the 5th injector, one piece is broken off but I think it's the half that isn't specific to 1996. $10 asking.
B4 LIGHTS
4 tail lights and 2 front markers, markers need help. I have 2 left outer, one left inner, and one right outer tail lights. $75 for all the lights.
B4 BODY PANELS
sedan rear bumper in black magic $50 asking, picked up.
Wagon rear bumper in blue, $50 asking, picked up.
Front bumper, was black magic. Started scuffing for paint. Never finished. $50 asking, picked up.
Front filler panel below headlights. Needs help but straight. $30 picked up.
Hood, sprayed in high build primer. Never got to blocking. $50 picked up.
Left fender, sprayed in high build primer. Never blocked, something fell on it and now has a dent. But can be fixed. $free to a good home, picked up.
B3/B4 PARTS
washer tank from a b3 with headlight sprayers. Both pumps worked, I used the second one for an intercooler sprayer. Bolts right into a B4. $25 asking
Leather puffy door cards, complete set. The do fit into a b4 if you add the screw inserts along the door centerline. I quite liked them in my car, nice look and large door pockets. $150 asking, prefer pickup.
B3 belt cover, I used to keep water off my belts when I was using my aluminum skid plate. Worked well. $20 asking.
B4 ASSORTED PARTS
box of door handles and latches, some good, some not so good. Some have keys, some do not. I will sort them out a bit better when. I have a chance, if you have something specific I will check. If you want the whole box $100 asking.
B4 foglights, and tow hook cover plates. I have one good set and a couple other pieces related to it. $100 asking.
MK4 PARTS
I have a 2 door golf, so everything I have is from that car.
Full set of beige seats, free to a good home driver seat has heavy bolster wear but can likely be fixed. Picked up.
Beige cargo cover. $20 picked up.
Beige front half of console, one tab broken. $10 prefer pickup
Passenger door card, leather, power. $10 pickup preferred
Cargo cover that doesn't actually look to be 2 door. Black in color. $20 picked up
Hatch trim, lower half. Have 2. $20 each, picked up.
Air box, I think it's actually for a gas car but the bottom half is the same. $20
If you need something, ask. I might have it, pictures are In my user album. There were close to 50 I uploaded and this post is quite Long already, I can get more on request and if I need to I can get on a computer and add them into this post. I am willing to meet within reason. i am also open to trade some parts if you have something I need. I am looking for a turbo for my AHU.
B4 BEIGE INTERIOR
B4 LIGHTS
B4 BODY PANELS
B3/B4 PARTS
B4 ASSORTED PARTS
MK4 PARTS
