That would be great if there were an actual relay. The AUX heat controller is a solid state device built in to the AUX heater. The best way to tell if it is installed and working is to look for a Z-35 measuring block in VCDS.
The 2015 EA288 engines are a completely new design and may not even have an AUX heater because of the 3 loop cooling system.
My 2015 Beetle has both the Aux heater and Hot country options.
Brand VOLKSWAGEN
Model NEW BEETLE DESIGN
VIN
Check digit Ok
Production date 2014-10-22
Model year 2015
Engine code CVCA (TDI)
Engine volume, L 2.00
Number of cylinders 4
Power, KW 110
Power, PS 150
Colour of body 8E (SILVER: reflexsilver metallic)
Colour of roof 8E (SILVER: reflexsilver metallic)
Trim JU
Gearbox code PGN (6A)
Country of sale 000 ()
Custom options
Parameter Value
E0A Special editions: No special edition
1PF Lockable wheel bolts: Standard wheel bolts
7KL Vehicle class differentiation units/platform components: Vehicle class differentiation 5C0
UG1 Hill start assist: Hill hold control
7MU Emissions standard: Emission standard LEV 3/Tier 3 125
1D0 Trailer hitch: Without trailer hitch
4UM Airbag: Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage)
1E9 Activated carbon canister: Without activated charcoal canister with SCR
QE2 Storage compartment package: Storage box
8L6 Antennas: "diversity" window antenna
6XN Exterior mirror setting: Exterior mirrors: electrically adjustable, separately heated
EA0 Follow-on warranty: Without subsequent warranty
5SH Left exterior mirror: Left exterior mirror: flat (US)
5RR Right exterior mirror: Right exterior mirror: convex (US)
0K0 Alternative drive system: Without alternative drive module
1X0 Drive layout: Front wheel drive
9WL "Multimedia", video/DVD/notebook connection: Multimedia socket for external audio source
A8C Equipment levels: Comfort equipment
1KD Brake type in rear: Disc brakes, rear
J1D Batteries: Battery 380 A (72 Ah)
1ZP Brake type, front: Disc brakes, front (Geomet D)
6FH Components with special surface appearance: Exterior mirror housings painted
NY0 Battery/alternator capacity: Standard battery/alternator capacity
B0D Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for USA (without California), various parts
3MH Floor coverings: Dilours floor covering w/o scuff guard
1S1 Tool kit and jack: Tool kit and jack
1AT Brake systems: Electronic stabilization program (ESP)
0VM Owner's manuals: Information kit in American English
9U0 Brake pad wear indicator: Without brake pad wear indicator
9T1 Heated washer nozzles: Heated washer nozzles, front
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
QJ1 Chrome package: Chrome work package
C16 General operating permit, alterations: Operating permit, alteration
3FA Roof insert/convertible top: Without roof insert (standard roof)
UA1 Suspension system in rear: Rear shock absorption
G58 Suspension system in front: Front shock absorption
2G9 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 2 with insert
0ES Installation differentiation for vehicle components: Installation differentiation for transmission DQ250 vehicle components
7AZ Theft protection system: Preparation for anti-theft alarm system
5MB Inserts: Decorative inserts
7M5 Scuff plates: Without protective film for scuff plate
7X0 Park distance control: Without park distance control
UQ3 Electric interface for external use: Electric interface for external use with an iPhone4 adapter cable
0FL Manufacturing sequence differentiation: Mexico manufacturing sequence
51A Adhesive film: Without adhesive film
4R4 Window regulator: Power windows with comfort operation and circuit breaker
6A0 Fire extinguishers: Without fire extinguisher
VL0 Pedestrian protection: Standard pedestrian protection measures
VF0 Pedal cluster: Standard pedal cluster
8K4 Headlight control: Separate daytime running lights NAR
7G0 Vehicle tracing system: Without preparation for VTS (vehicle tracking system)
F0A Vehicle specifications: No special purpose vehicle, standard equipment
8GU Alternators: Alternator 140 A
0YD Weight category rear axle: Weight range 4 installation control only, no requirement forecast
L13 Weight category front axle: Suspension range 13 installation control only, no requirement forecast
T0N Base engine: 4-cylinder diesel engine 2.0 l unit 04L.D
4U5 Luggage net/pocket on backrest(s): Luggage pockets on backrest
8T2 Cruise control system: Cruise control system (CCS) electronic
2B0 Exterior noise suppression measures: Without additional exterior noise suppression
G1A Transmission specifications: 6-speed automatic transmission
4Z4 Glove compartment: Glove compartment door without light
3P0 Brackets: Without bracket for first aid kit and warning triangle
IA2 Bracket: With bracket
6PC Hand brake lever handle: Leather hand brake lever handle
5J0 Rear spoiler: Without rear spoiler
5N1 Grab handles at roof frame: Folding grab handles
0N4 Rear axle: 4-link rear suspension
3KC Rear seats: Rear seat bench unsplit, backrest split folding
9AB Heating and air conditioning system: Manually controlled air conditioning
8IA Headlamps: Halogen headlight
FC0 Customized installation: Without customized installation
U5C Instrument clusters: Instrument insert, mph speedometer USA
4N3 Dashboard: Comfort dashboard
4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror
K8F Body style: Roundback
1W0 Refrigerator: Without refrigerator/glove compartment cooling system
0Y3 Climatic zones: Cold zones
3Q1 Rear head restraints: Rear headrests
3J2 Head restraints: Height-adjustable headrests
2LC Fuel tank treatment: Fuel tank with special material treatment (coextrusion)
1Z0 Fuel quantity for initial filling: Initial standard fuel filling
0F5 Fuel systems: Fuel system for diesel engine
5C1 Body measures: Body measures for increased safety requirements
KA0 Camera systems/accident sensors: Without camera systems/accident sensors
6KA Radiator grille: Radiator grille
KL0 License plate lighting: Standard license plate lighting
6P2 Rear license plate carrier: Rear license plate carrier (NAR)
6W3 Front license plate carrier: Front license plate carrier (small, NAR)
5K7 Paint preservative/transit coating: Transport protection film (minimum protection) with additional transport protection measures
QQ2 Light package (lighting): With additional lights (interior lighting)
L0L Steering system arrangement: Left-hand drive vehicle
8S8 Reading light: 2 reading lights
1N3 Steering: Speed-related variable steering assist (Servotronic)
3H9 Backrest release: Backrest release for front seats with "Easy Entry"
VK1 Air duct, front area: Air duct, type 1
7P4 Lumbar support: Manually adjustable lumbar support in front seats
2FQ Steering wheels: Leather trimmed multi-function sports steering wheel w/ Tiptronic
AV2 Driving on the left/on the right: Driving on the right (NAR)
8RM Speaker installation: 8 speakers (passive)
8Q0 Headlight range control: Without headlight-range adjustment
6E4 Center armrest: Front center armrest
9Q5 Multi-function display/trip computer: Multi-function display with control
8Z6 Engine cooling system: Hot country
DN4 Engine specifications: 4-cylinder turbo diesel engine 2.0 l/110 kW (4V) TDI common rail| b.e. T37/ TS1/TR1/T0P/T0N/T13/T29/TM4/TD1/TI9/T1I
AW0 Market-specific vehicle version: Version (low)
7Q0 Navigation device: Without navigation device
8TA Rear fog lamp: Without rear fog light
8WA Front fog lamp/additional headlamp: Without front fog light
EL2 Online services: Online service, with OCU, without head unit coding, without engine immobilizer interconnection
4P0 Platform module, luggage compartment floor: Rear floor panel module, type 1
7PB Platform group class: Platform group class 2
KP4 Panic switch: With additional switch
FR8 Protective cover/tonneau cover: Without protective cover
1NL Wheel covers: Covers for alloy wheels
F33 Wheels: Alloy wheels 7J x 17
8AX Radios: Radio Premium 8
9JF Smoker's/non-smoker's package: Non-smoking package (NAR)
7K6 Direct tire pressure monitoring system: Flat tire indicator
H6C Tires: All-weather tires 215/55 R17 94H (NAR)
V0A Tire suppliers: Tires w/o specification of tire brand
1G6 Spare wheel/breakdown kit: Space-saving spare wheel
3QR Restraint systems, front: 3-point seat belts without height adjustment and US label (NAR), front
4X3 Side airbag: Side air bag front with curtain air bag
6Q2 Gearshift knob/handle: Leather gearshift knob/handle
0SC Special labels/plates: Labels/plates in English
8SA Rear combination lamps: Taillight assemblies, standard design
QI7 Service indicator: Service indicator ( 10000 miles )
3TF Front seat, left: Comfort seat, front left
3SF Front seat, right: Comfort seat, front right
QD0 Nameplate for sales name: Without lettering for sales name
9P7 Seat belt check: Seat belt reminder, optical and acoustic electric contact in buckle
3ZD Outer rear seat belts: 3-point seat belts, outer rear with US label
N2Q Seat trim covers: Leatherette seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
7R7 Side lights: Side marker lights plus additional turn signal lights in exterior mirrors
7L3 Start-stop system/regenerative braking: Without start/stop system without regenerative braking
8Y4 Horns: High-sounding horn
5XX Sun visors: Sun visors with mirror, illuminated (NAR)
7Y0 Lane change assist/lane keeping system: Without lane change assistant
4KC Side and rear windows: Side and rear windows in heat-insulating glass
4B4 Protective side molding: Protective side molding
7B5 Socket: 12-volt socket(s)
2JG Bumpers: Body-colored bumpers
0BG Rear stabilizer bar: Rear stabilizer
0AB Front stabilizer: Front stabilizer
2UA Heavy-duty/sports version: Standard design
8X0 Headlamp washer system: Without headlight washer system
8N4 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with potentiometer (four speeds)
2Y0 Protection frame (roll bar): Without roll bar
0ND Nameplate set: Nameplate set "TDI"
6JD Door handles/inlays: Body-colored door handles
1Q1 Mass damper for steering wheels: Mass damper for steering wheel, 26.5Hz
4F6 Door and lid locking system: Central locking system "Keyless Entry" without deadlock (NAR)
BU1 Type approval countries/countries with special requirements: Legal requirements USA 1 States without CARB requirement
5D2 Carrier frequency for radio remote control: Carrier frequency 315 MHz
4AB Door and side trim panels: Door and side trim panel partially in leather
0A1 Doors: 2 doors
QU4 TV reception/digital radio reception: Satellite radio reception NAR integrated in device
1SA Front underbody guard: Without additional front underbody guard
1EB Identification plates: Without identification plate
1T0 First aid kit / warning triangle: Without first aid kit and warning triangle
9ZR Telephone / telematics: Preparation for telephone without 3-key module
7S0 Wind deflector: Without wind blocker
QG1 Service interval prolongation: Service interval prolongation
7E6 Heat accumulator system/auxiliary heater: Electric auxiliary air heater
4GS Windshield glass type: Heat-insulating glass windshield
5M0 Strip and films all-around: Without warning strip and films
8W1 Washer fluid level indicator: Washer fluid level indicator
2WA Additional tires (snow tires): Without additional tires
0TD Floor mats: Front and rear floor mats
4ZC Decorative trims: Moldings
3B7 Additional child seat anchors: Child seat anchor according to Canadian requirements and child seat system ISOFIX
9M0 Auxiliary heater: Without auxiliary/parking heater
System information
Parameter Value
Data language en
Record was added in database 2019-01-04 13:29
Last query date 2019-01-04 13:29
Last update date 2019-01-04 13:29
Brand VOLKSWAGEN
Data display version 2.0
Manufacturer's data version 8.0.0.23 rev 1244 from 2018-09-24
