Auto's fat brake pedal
PakProtector
AnnArbor, MI
Mk.4 and the Cummins-es
The fat brake pedal the auto cars come with is making a PITA of itself. It helps not at all that my feet are not small. I see two options; one to fight out the auto brake pedal box( and that of the donor ), and install the skinny manual pedal, or break out a saw and trim the fat auto one. Seems like the biggest issue is getting the booster connection to let go of the pedal...nothing I have seen yet says this is easy with less than 3 hands and/or a special tool. I'd love to hear about something that is not going to have me stuck in a 5 hour cursing session...
cheers,
Douglas
There are two different SSTs available to release the brake pedal rod. I have them both.
3289
T10006A
The latter is easier to use, but it still is awkward.
PakProtector
AnnArbor, MI
The T10006A is not looking like a bad acquisition. IDP to the rescue for ~$35. Given your 'awkward' description, I am not holding my breath for the pedal block to leap out when I show it the tool...LOL
cheers,
Douglas
PakProtector
AnnArbor, MI
Every manual swap I've done, I've simply drilled the spot welds on the pedal and popped off the stamped metal that "extends" it to a wide pedal. Every auto pedal is secretly a manual pedal in disguise.
Noooo...
Do tell a bit more. Crayon sketch also useful.
cheers,
Douglas
greengeeker
Cambridge, MN
2002 Jetta GLS
Same here. Just get a mirror and look on the backside of the auto pedal. You'll see the manual pedal hiding out. To be clear there are 4-5 spot welds as well as 2x fillet welds along the sides to cut out. The latter are more a pain than the former. But still easier than getting that damn brake pedal out....Brian's description is spot on.
It is one of those situations where you have to stick your tongue out a little, lift one leg, and squint one eye, and hopefully the planets are aligned and it is not a full moon. THEN it will pop right off, LOL.
Nero Morg
OR
Unless someone beats me to the punch, I'll take a photo on my next break lol
greengeeker
Cambridge, MN
2002 Jetta GLS
You can see the spot welds and then he shows a picture of the mirror - that shows the fillet welds you need to cut/grind off and then you can just knock off the big auto pedal.
Nero Morg
OR
That's a good picture there. I ended up just drilling the five dimpled areas, then used a pair of vice grips to convince it off. No need to get out the angle grinder.
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
The trick I made use of was taking a propane torch to the metal area that contains the plastic rod-holder for the brake booster plunger (or whatever it is). Soften up the plastic with heat (a heat gun might be safer than propane torch, but ya dance with who ya got at the time), then give the brake pedal a good solid yank back toward the driver seat....popped loose first attempt on both cars I tried it on. Plastic thing on the brake pedal even stayed intact (not that I had to use it - my manual pedal had a good one).
Got the idea from a youtube video. Basic run-through here:
PakProtector
AnnArbor, MI
Well, I thank you gents for the suggestions and documentation. Something is going to happen this weekend... :)
cheers,
Douglas
Nero Morg
OR
Took a photo of mine so you can see what it looks like post-wide pedal removal. I took the rubber pad off so you can see it. Putting the pad back on, can't tell it was modified.
Nuje
What am I missing? Looks like a manual brake pedal that you drilled some holes in (I'm assuming to accept the pad?).
Nero Morg
OR
It was an auto pedal, you drill the welds in the dimpled area, then you can remove the entire steel plate that vw put on there to widen it. Beneath the wide sheet steel is a manual pedal.
Nuje
Ahhhh - I'd never pulled the rubber cover off to look at the metal underneath on an 01M's brake pedal.
Good move!
PakProtector
AnnArbor, MI
Thanks Nero, I attacked that pedal with rakes, picks, shovels and other implements of destruction and then applied a manual's brake pedal pad. No more putting self thru windshield when grabbing clutch for the first 1-2 shift... :)
cheers,
Douglas
csstevej
north nj
Ohhhh I like this mod……..gonna have to do this on my swapped car.
PakProtector
AnnArbor, MI
Before you get too happy, there is a 6th weld there on the left. I got my 5 top ones free and then just broke the pedal's cap off. Then tunred the remainder to dust...maybe Nero can shed some light on getting to that one while in-car.
cheers,
Douglas
Nero Morg
OR
I just grab it with vice grips then bend the weld back and forth until it snaps. First bend is usually a little challenging, but after a few back and forths it pops off.
PakProtector
AnnArbor, MI
HA! that is how I dealt with it. Nice low carbon steel there; it took a bit of back and forth to get it separated. The remaining bit I turned to dust.
cheers,
Douglas
