Originally posted by Coolin:
From the FAQ:
The automatic transmission used in these vehicles increases fuel consumption by about 20% compared to the manual transmission.
Can anyone give me a good explanation as to why this is...with Highway and City examples...
<font size="2" face="Verdana, Helvetica, sans-serif">Transport Canada figures for city driving are 6.9 L/100 km automatic, 5.6 L/100 km manual (automatic 23% more consumption).
Transport Canada figures for highway driving are 4.8 automatic, 4.4 manual. (automatic 9% more consumption).
Every transmission needs a method of "slipping" to move the vehicle away from a standstill. The engine must continue rotating but the car is stopped and needs to get moving. Slippage means that power which the engine consumes fuel to produce is getting thrown away as heat. Slippage is NO GOOD for efficiency but you need at least a little bit to get away from a standstill.
With a manual this slippage is done by a mechanical clutch and the slippage is over with by 10 km/h and the engine speed going barely above idle during this process if the driver is any good. At anything above that speed it is pure mechanical gear reduction, which is very efficient. Also the manual transmission doesn't require any power to hold itself in gear. Once you put the tranny in gear it's there. No effort is expended by the engine to keep the transmission engaged.
With an automatic the slippage is done by a torque converter. It is basically a centrifugal pump driving a turbine. The faster you spin the pump the more force is developed at the turbine. To move away from a standstill this whole setup sloshes fluid around (the "slushbox" nickname for an auto tranny is well deserved) and it keeps sloshing this fluid around (slipping, and throwing away power in the process) until you are well into third gear and moving probably 50 to 70 km/h. In other words, if you are driving around town this tranny is throwing away a big percentage of the power produced by the engine.
At higher speeds, the converter has a lockup clutch that eliminates the slippage losses. But look at how an auto tranny engages this lockup clutch and the clutches that operate the gears: HYDRAULICS. Even on the highway, there is a little hydraulic pump running all the time, eating up a little bit of power, just to keep the transmission engaged via the hydraulic system.
Thus ... an auto tranny can't touch a manual for efficiency unless the manual tranny driver has no clue what to do.
And it also seems to be that this auto tranny is worse off for efficiency than others.
Why not lock the converter clutch as soon as the car moves away from a standstill, just like a manual? Because then you'll feel every gearshift with a slam. The converter acts like a big cushion. Most drivers of auto trannies don't want to know what the tranny is doing, and if the converter is locked, you'll feel every shift ...
Want optimum efficiency? buy a manual tranny.
